Full Version: manual choice
There seems to be a bug if you scraped all your movies for example and need to fix several entries:
If you update a movie, you get the result lists by the scraper, including a "manual" option which allows you to redefine the query for the request. But it seems to be impossible to alter your choice, if you already picked an entry from the result list and want to adapt the movie a second time :/
