Full Version: Problem with mapping under 3.9
Hey,
I install TVHeadend in version 3.9.
The adapter is enabled, idle scan and initial scan is marked and Satconfig says: Universal LNB only.
Channels are scanned and now I want to add the channels to my channellist.
Therefore I search the channel under Configuration DVB Input > Services, mark this channel and click Map selected.
This is working, unless I'm not trying to add a channel where the Encryption is marked (hd+ channels/sky channels).
I use the same CA's as in version 3.4, where I have no problem adding those channels.
Furthermore when I click Play in TVHeadend for a channel I'm not able to map, VLC opens and I can watch this channel.
So encryption should be fine.
Damn. This was to easy...
.. When clicking Map selected, mark Include encrypted services.. that solves the problem.
