2015-01-12, 14:02
Hi guys
Over the years I amassed a huge DVD library and most of my DVDs are from the US (I live in Greece). As a result those DVDs run at 29.9 FPS.
I have a hard time finding subtitles that work with my DVDs from the online tool that Kodi comes with (the subtitles button when you start the movie).
I tried to download some subtitles and re-sync/convert them my self but I run into the following problem.
I can't make kodi see my external subtitles. I store my DVD's as folders on the hard drive (the usual folders, AUDIO_TS and VIDEO_TS) because I don't want any compression on them since I will loose quality from doing that).
So the way I use subtitles is this, I find the one I want.. re-sync it and then store it in the VIDEO_TS folder of the movie as Video_TS.srt.. the same method that kodi uses when u download a subtitle from inside the player.
But Kodi doesn't see the subtitle....
If I use Kodi to download a subtitle it uses it but as soon as I close the movie and restart it again kodi doesn't see the subtitle it I originally downloaded and I have to re-download the file in order for kodi to play it.... and ofc as a result I can't replace the subtitle that kodi downloaded with the resynced subtitle I made because kodi will not see it until I make it download it again in which case it will overwrite my synced one with the one from the internet.
In sort is there a way to make Kodi see external subtitles for movies that follow the original DVD storage method (just copying the contents of the dvd into a folder)?
