Full Version: Kodi occasionally crashes on Mac OS X
Hello,
I am using a Mac Mini with Kodi 14 (the issue first occured back on Gotham, though). I usually have Kodi running all the time (it's a dedicated PC for this) and from time to time when I come back to it after a break - it crashes. Here is the crash report from Mac OS X (It's 10.10 Yosemite): https://www.dropbox.com/s/odks0je52mk7j1...t.log?dl=0
Let me know if you need xbmc.log as well (not sure if it's not the same).
Thanks for your assistance.
i had exactly the same problem. Crashes, reboots etc. I upgraded to the 14.1 testbuild of January 9th, so far no more crashes.
http://forum.kodi.tv/showthread.php?tid=213108
I just noticed there is a new 12th january build, Ill install that one right away.
So you are saying that the Stable build is unstable and I should try the newest dev builds to resolve this? Smile Wondering when 14.1 is going to be released as Stable Smile
(2015-01-14, 10:06)wjarka Wrote: [ -> ]So you are saying that the Stable build is unstable and I should try the newest dev builds to resolve this? Smile Wondering when 14.1 is going to be released as Stable Smile
Uhh yeah and the build of january 12th is crashing after about 10 hours inactivity. Soooo ill go back to the january 9th build. A lot of chrashes are reported all over the forum so i guess its being worked on.
