Full Version: Auto Update Music Library
Hello,
i have an USB Stick on my Raspberry PI with all the mp3 of my music. If i add new songs to it how can i configure kodi to scan the usb stick automaticaly or permanently?
Thanks a lot
Try "updating library on startup" in system settings
Thanks i know this setting, But this setting only works on restart. I remove the usb stick add a music file and then put it again to my raspberry. Then I would like that kodi rescan the usb stick and add new files to the library.
then you have to do it manually
Check out the addon Watchdog. I've never used it, but it may be what you are looking for.
What you are asking for is not built into Kodi itself.
ok many thanks to all.
