Full Version: Audio track not being remembered
I use Kodi to watch IPTV via IPTV Simple add-on. There are a lot of TV streams with multiple audio tracks. On Gotham I could select an audio track and next time I played that stream the same audio track was chosen (the track was remembered for each stream). Looks like this behaviour has changed in Kodi. If for example I select the 2nd audio track while watching one stream and then switch to another streams the 2nd audio track gets picked up for those streams too. So it looks like Kodi remembers the track number and tries to play the track with the same number for all streams. The same happens if I select any other track - track number is being remembered for all the other streams. This wasn't an issue on Gotham, audio tracks were remembered correctly for all streams.
Has anyone else experienced this?
kornaz
