Full Version: PVR IPTV Simple Client xbmc Gotham 13.2
I have a raspberrypi with xbmc Gotham 13.2 software installed and I’m trying to setting up the PVR IPTV simple Client 1.9.3 add-on without success.
I have already installed the add-on plugin “pvr.iptvsimple.1.9.3.win32” through install from zip file option, but when I'm trying to activate the pvr client plugin the following an error is returned:
ERROR: ADDON: Could not locate XBMC_IPTV_Simple.pvr
After googling about this error it seems that zip file was compiled to windows and not arm (raspberrypi) architecture.
My question is: where can I find the pvr.iptvsimple.1.9.3 zip file compiled to arm architecture to install on raspberrypi?
Meanwhile, I have already tried to install the add-on plugin through “apt-get install xbmc-pvr-iptvsimple” command, but I don’t know how to activate them because it is not visible in the xbmc enable/disable add-ons section.
Any suggestions? I would be very grateful for your help.
What distribution do you use on your Pi? If you're on Raspbian or some other Debian-based distribution, use apt-get to install the addon (search for kodi-pvr). If you're using Openelec you should have all the addons already in a disabled state.
Yes, it's Raspbian (2014-09-09) version.
I have already installed the add-on through apt-get install, see output:
root@raspberrypi ~ $ dpkg --get-selections | grep pvr
kodi-pvr-iptvsimple install
xbmc-pvr-iptvsimple install
xbmc-pvr-tvheadend-hts install
After that, it should be visible in xbmc enable/disable add-ons pvr clients but it isn't. :/
Is there any other step that i have missed?
Thanks for your help.
please can someone help me to get the zip file for iptv client xbmc 13.2 android tv boxAngel
@montijo try removing and installing it again.
Which repository you use?
I tryed:
add-apt-repository ppa:team-xbmc/ppa
aptitude update && aptitude upgrade
and see nothing:
root@7th_odroid:~# apt-cache search kodi
kodi - Kodi Media Center (arch-independent data package)
kodi-eventclients-common - Kodi Media Center (Event Client Common package)
kodi-eventclients-dev - Kodi Media Center (Event Client Dev package)
kodi-eventclients-j2me - Kodi Media Center (Event Client J2ME package)
kodi-eventclients-ps3 - Kodi Media Center (Event Client PS3 package)
kodi-eventclients-xbmc-send - Kodi Media Center (Event Client Kodi-SEND package)
kodi-addon-dev - Kodi Media Center (General Add-on Dev package)
kodi-screensaver-dev - Kodi Media Center (Screensaver Add-on Dev package)
kodi-visualization-dev - Kodi Media Center (Visualization Add-on Dev package)
kodi-pvr-dev - Kodi Media Center (PVR Add-on Dev package)
kodi-audio-dev - Kodi Media Center (Audio Add-on Dev package)
(Ubuntu 14.04.2, arm, Kodi 14.2-BETA2)
Looks like packages for arm are missing at the moment.
(2015-05-15, 14:01)negge Wrote: [ -> ]Looks like packages for arm are missing at the moment.
No way for me?
we don't provide any ARM packages for ubuntu. So you should ask wherever you got kodi from.
