2015-01-14, 21:14
I can't figure out why this issue is occurring, I've been able to determine that any time I run kodi as its service user (which is a member of audio and video groups) and try to play a video it immediately crashes. If I run it as root then everything works exactly as expected. The entire settings directory is owned by the service user (xbmc), what's going on?
Running on Fedora 21[/code]
Here's the crash log:
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: Wed Jan 14 20:10:37 CET 2015
Kodi Options:
Arch: x86_64
Kernel: Linux 3.17.8-300.fc21.x86_64 #1 SMP Thu Jan 8 23:32:49 UTC 2015
Release: Fedora 21 (Twenty One)
############## END SYSTEM INFO ##############
############### STACK TRACE #################
############# END STACK TRACE ###############
################# LOG FILE ##################
20:10:34 T:140661565991296 NOTICE: special://profile/ is mapped to: special://masterprofile/
20:10:34 T:140661565991296 NOTICE: -----------------------------------------------------------------------
20:10:34 T:140661565991296 NOTICE: Starting Kodi from RPM Fusion (14.0 Git:Unknown). Platform: Linux x86 64-bit
20:10:34 T:140661565991296 NOTICE: Using Release Kodi x64 build
20:10:34 T:140661565991296 NOTICE: Kodi compiled Jan 6 2015 by GCC 4.9.2 for Linux x86 64-bit version 3.17.7 (200967)
20:10:34 T:140661565991296 NOTICE: Running on Fedora 21 (Twenty One), kernel: Linux x86 64-bit version 3.17.8-300.fc21.x86_64
20:10:34 T:140661565991296 NOTICE: FFmpeg version: 2.4.5
20:10:34 T:140661565991296 NOTICE: WARNING: unsupported ffmpeg version detected
20:10:34 T:140661565991296 NOTICE: Host CPU: Intel(R) Core(TM) i3-3220T CPU @ 2.80GHz, 4 cores available
20:10:34 T:140661565991296 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
20:10:34 T:140661565991296 NOTICE: special://xbmcbin/ is mapped to: /usr/lib64/kodi
20:10:34 T:140661565991296 NOTICE: special://masterprofile/ is mapped to: /var/lib/xbmc/.kodi/userdata
20:10:34 T:140661565991296 NOTICE: special://home/ is mapped to: /var/lib/xbmc/.kodi
20:10:34 T:140661565991296 NOTICE: special://temp/ is mapped to: /var/lib/xbmc/.kodi/temp
20:10:34 T:140661565991296 NOTICE: The executable running is: /usr/lib64/kodi/kodi.bin
20:10:34 T:140661565991296 NOTICE: Local hostname: gaia.haiti
20:10:34 T:140661565991296 NOTICE: Log File is located: /var/lib/xbmc/.kodi/temp/kodi.log
20:10:34 T:140661565991296 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
20:10:34 T:140661565991296 NOTICE: load settings...
20:10:34 T:140661565991296 NOTICE: Found 1 Lists of Devices
20:10:34 T:140661565991296 NOTICE: Enumerated ALSA devices:
20:10:34 T:140661565991296 NOTICE: Device 1
20:10:34 T:140661565991296 NOTICE: m_deviceName : @
20:10:34 T:140661565991296 NOTICE: m_displayName : Default (HDA Intel PCH VT1708S Analog)
20:10:34 T:140661565991296 NOTICE: m_displayNameExtra:
20:10:34 T:140661565991296 NOTICE: m_deviceType : AE_DEVTYPE_PCM
20:10:34 T:140661565991296 NOTICE: m_channels : FL,FR
20:10:34 T:140661565991296 NOTICE: m_sampleRates : 48000
20:10:34 T:140661565991296 NOTICE: m_dataFormats : AE_FMT_S32NE
20:10:34 T:140661565991296 NOTICE: Device 2
20:10:34 T:140661565991296 NOTICE: m_deviceName : @:CARD=PCH,DEV=0
20:10:34 T:140661565991296 NOTICE: m_displayName : HDA Intel PCH
20:10:34 T:140661565991296 NOTICE: m_displayNameExtra: VT1708S Analog
20:10:34 T:140661565991296 NOTICE: Device 3
20:10:34 T:140661565991296 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=0
20:10:34 T:140661565991296 NOTICE: m_displayNameExtra: HDMI
20:10:34 T:140661565991296 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
20:10:34 T:140661565991296 NOTICE: m_sampleRates : 44100,48000,88200,96000,192000
20:10:34 T:140661565991296 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_LPCM,AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC
20:10:34 T:140661565991296 NOTICE: Device 4
20:10:34 T:140661565991296 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=1
20:10:34 T:140661565991296 NOTICE: m_displayNameExtra: SAM SAMSUNG on HDMI
20:10:34 T:140661565991296 NOTICE: m_sampleRates : 32000,44100,48000
20:10:34 T:140661565991296 NOTICE: m_dataFormats : AE_FMT_LPCM,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC
20:10:34 T:140661565991296 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
20:10:34 T:140661565991296 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
20:10:34 T:140661565991296 NOTICE: Default DVD Player: dvdplayer
20:10:34 T:140661565991296 NOTICE: Default Video Player: dvdplayer
20:10:34 T:140661565991296 NOTICE: Default Audio Player: paplayer
20:10:34 T:140661565991296 NOTICE: Disabled debug logging due to GUI setting. Level 0.
20:10:34 T:140661565991296 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
20:10:34 T:140661565991296 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
20:10:34 T:140661565991296 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
20:10:34 T:140661565991296 NOTICE: Loaded playercorefactory configuration
20:10:34 T:140661565991296 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
20:10:34 T:140661565991296 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
20:10:34 T:140661459601152 NOTICE: Thread ActiveAE start, auto delete: false
20:10:34 T:140661451208448 NOTICE: Thread AESink start, auto delete: false
20:10:34 T:140661565991296 NOTICE: Running database version Addons16
20:10:34 T:140661565991296 NOTICE: ADDONS: Using repository repository.xbmc.org
20:10:34 T:140661435729664 NOTICE: Thread PeripBusCEC start, auto delete: false
20:10:34 T:140661427336960 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
20:10:34 T:140661565991296 NOTICE: Setup SDL
20:10:34 T:140661565991296 NOTICE: Checking resolution 16
20:10:34 T:140661565991296 NOTICE: Using visual 0x20
20:10:34 T:140661565991296 NOTICE: GL_VENDOR = Intel Open Source Technology Center
20:10:34 T:140661565991296 NOTICE: GL_RENDERER = Mesa DRI Intel(R) Ivybridge Desktop
20:10:34 T:140661565991296 NOTICE: GL_VERSION = 3.0 Mesa 10.4.1
20:10:34 T:140661565991296 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
20:10:34 T:140661565991296 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_AMD_performance_monitor GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_conservative_depth GL_AMD_draw_buffers_blend GL_AMD_seamless_cubemap_per_texture GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_cube_map_array GL_ARB_texture_gather GL_ARB_texture_multisample GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_texture_compression_bptc GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_shader_atomic_counters GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_ARB_transform_feedback_instanced GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_AMD_shader_trinary_minmax GL_ARB_ES3_compatibility GL_ARB_clear_buffer_object GL_ARB_copy_image GL_ARB_explicit_uniform_location GL_ARB_invalidate_subdata GL_ARB_texture_query_levels GL_ARB_texture_storage_multisample GL_ARB_texture_view GL_ARB_vertex_attrib_binding GL_KHR_debug GL_ARB_buffer_storage GL_ARB_clear_texture GL_ARB_multi_bind GL_ARB_seamless_cubemap_per_texture GL_ARB_texture_mirror_clamp_to_edge GL_ARB_vertex_type_10f_11f_11f_rev GL_EXT_shader_integer_mix GL_INTEL_performance_query GL_ARB_conditional_render_inverted GL_ARB_derivative_control GL_KHR_context_flush_control
20:10:34 T:140661565991296 NOTICE: Running database version ViewModes6
20:10:34 T:140661565991296 NOTICE: Running database version Textures13
20:10:34 T:140661565991296 NOTICE: Running database version MyMusic48
20:10:34 T:140661565991296 NOTICE: Running database version MyVideos90
20:10:34 T:140661565991296 NOTICE: Running database version TV26
20:10:34 T:140661565991296 NOTICE: Running database version Epg8
20:10:34 T:140661565991296 NOTICE: start dvd mediatype detection
20:10:34 T:140661400286976 NOTICE: Thread DetectDVDMedia start, auto delete: false
20:10:34 T:140661565991296 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
20:10:34 T:140661565991296 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
20:10:34 T:140661565991296 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
20:10:34 T:140661565991296 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
20:10:34 T:140661154748160 NOTICE: Thread LanguageInvoker start, auto delete: false
20:10:34 T:140661565991296 NOTICE: Previous line repeats 1 times.
20:10:34 T:140661565991296 NOTICE: initialize done
20:10:34 T:140661565991296 NOTICE: Running the application...
20:10:34 T:140661146355456 NOTICE: Thread LanguageInvoker start, auto delete: false
20:10:34 T:140661154748160 NOTICE: Previous line repeats 1 times.
20:10:34 T:140661154748160 NOTICE: -->Python Interpreter Initialized<--
20:10:34 T:140661565991296 NOTICE: starting zeroconf publishing
20:10:34 T:140661565991296 NOTICE: Webserver: Starting...
20:10:34 T:140661565991296 NOTICE: WebServer: Started the webserver
20:10:34 T:140661565991296 NOTICE: starting upnp renderer
20:10:34 T:140660763883264 NOTICE: Thread JobWorker start, auto delete: true
20:10:34 T:140661565991296 NOTICE: ES: Starting event server
20:10:34 T:140660631918336 NOTICE: Thread EventServer start, auto delete: false
20:10:34 T:140660631918336 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
20:10:34 T:140660631918336 NOTICE: UDP: Listening on port 9777
20:10:34 T:140660615132928 NOTICE: Thread JobWorker start, auto delete: true
20:10:34 T:140660623525632 NOTICE: Thread TCPServer start, auto delete: false
20:10:34 T:140660606740224 NOTICE: Thread AirPlayServer start, auto delete: false
20:10:34 T:140661400286976 NOTICE: Thread RSSReader start, auto delete: false
20:10:34 T:140661137962752 NOTICE: -->Python Interpreter Initialized<--
20:10:34 T:140661146355456 NOTICE: Previous line repeats 1 times.
20:10:34 T:140661146355456 NOTICE: StorageServer Module loaded RUN
20:10:34 T:140661146355456 NOTICE: StorageClient-2.5.4 Starting server
20:10:37 T:140661565991296 NOTICE: DVDPlayer: Opening: /media/Movies/John Wick/John.Wick.2014.720p.WEB-DL.DD5.1.H.264-PLAYNOW.mkv
20:10:37 T:140661565991296 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
20:10:37 T:140660594042624 NOTICE: Thread DVDPlayer start, auto delete: false
20:10:37 T:140660594042624 NOTICE: Creating InputStream
20:10:37 T:140660594042624 NOTICE: Creating Demuxer
20:10:37 T:140660594042624 NOTICE: Opening stream: 0 source: 256
20:10:37 T:140660594042624 NOTICE: Creating video codec with codec id: 28
20:10:37 T:140660594042624 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
20:10:37 T:140660594042624 NOTICE: Creating video thread
20:10:37 T:140660594042624 NOTICE: Opening stream: 1 source: 256
20:10:37 T:140660594042624 NOTICE: Finding audio codec for: 86019
20:10:37 T:140659415566080 NOTICE: Thread DVDPlayerVideo start, auto delete: false
20:10:37 T:140659415566080 NOTICE: running thread: video_thread
20:10:37 T:140660594042624 NOTICE: Creating audio thread
20:10:37 T:140660594042624 NOTICE: Opening stream: 2 source: 256
20:10:37 T:140659407173376 NOTICE: Thread DVDPlayerAudio start, auto delete: false
20:10:37 T:140659407173376 NOTICE: running thread: CDVDPlayerAudio::Process()
20:10:37 T:140659407173376 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through)
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
