2015-01-15, 12:56
I really need your help, due I’m not able to solve this problem by my own.
I got a HTPC with Ubuntu 14.04 LTS and Kodi running. It has taken some time, by except of one issue, everything is working fine now.
This remaining issue is, that I’m sometimes not able to turn on the HTPC via my remote (Logitech Harmony One+).
I could not figure out a pattern, when this issue occurs. For me it seems to be random..
Hardware:
MB: ASRock B85M-ITX
CPU: Intel i3-4150
RAM: 4GB
IR Receiver: CoHaus RC6 USB Dongle
Remote: Logitech Harmony One+
The remote is working pretty good out of the box with lirc, when kodi is started.
Example of the issue:
In the evening (when I’m going to bet), I turn of the HTPC with my remote (should be power toggle which is deposited and the harmony took for the action).
At the morning, I try to turn on the HTPC. I’m pressing my defined action.. TV turns on.. AVR turns on .. HTPC does not turn on.
Therefore I configured the power toggle button in the Harmony screen. When I’m pressing this button two times, the HTPC turns on.
When I now would shutdown the HTPC, I normally just had to click power toggle one time and the HTPC turns on..
If I wait some time, I need two press it two times again to power on (if he turns on at all..)
So far.. this is the „working“ setup..
Ok.. when I drive to work, I shutdown the HTPC. 10 hours later, when I came back from work, I’m no able to turn on the HTPC as described above and need to press the power button on the chase.
The 10 hours is not a fixed value for this issue. This could also occur after 2-3 hours, or 5 hours, or 1 hour.. As written before, I could not find a repeatable behavior.
I pretty much crawled the whole internet for fixes for this problem, without any success so far.
What I’ve done so far:
Also enabled power on by usb in BIOS.
What I do not unterstand is, that here:
are just shown one USB port. I’ve got at least 3x USB 2.0 and 3x USB 3.0.
The dongle is connected to a USB 2.0 port. Regardless of which USB port I connect the USB dongle, there keeps just USB1 without the possibility to enable this one (because of missing pic address I guess).
Pretty don’t know what to do next.
Hoping one of you have an idea.
Thanks in advance.
Hardware:
MB: ASRock B85M-ITX
CPU: Intel i3-4150
RAM: 4GB
root@xbmc:~# tail -3 /etc/rc.local
echo enabled > /sys/bus/usb/devices/3-2/power/wakeup
echo enabled > /sys/bus/usb/devices/usb3/power/wakeup
exit 0
root@xbmc:~# cat /etc/udev/rules.d/90-mcewakeup.rules
SUBSYSTEM=="usb", ENV{ID_VENDOR_ID}=="147a", ENV{ID_MODEL_ID}=="e03e" RUN+="/bin/sh -c 'echo enabled > /sys$env{DEVPATH}/../power/wakeup;echo enabled > /sys$env{DEVPATH}/power/wakeup'"
root@xbmc:~# cat /proc/cmdline
BOOT_IMAGE=/vmlinuz-3.13.0-44-generic root=/dev/mapper/live--vg-root ro quiet splash usbcore.autosuspend=-1 acpi_enforce_resources=lax vt.handoff=7
root@xbmc:~# grep ^DISABLE_KERNEL_SUPPORT /etc/init.d/lirc
DISABLE_KERNEL_SUPPORT=false
root@xbmc:~# cat /proc/acpi/wakeup
Device S-state Status Sysfs node
USB1 S3 *disabled
RP01 S4 *disabled pci:0000:00:1c.0
RP03 S4 *disabled pci:0000:00:1c.2
GLAN S4 *disabled
EHC1 S4 *enabled pci:0000:00:1d.0
EHC2 S4 *enabled pci:0000:00:1a.0
XHC S4 *enabled pci:0000:00:14.0
HDEF S4 *disabled pci:0000:00:1b.0
PEG0 S4 *disabled
PEGP S4 *disabled
PEG1 S4 *disabled
PEG2 S4 *disabled
Thanks in advance.
