Full Version: [RELEASE] Amazon Prime Instant Video (US/UK/DE)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
Does anybody know if its possible to trick Amazon into giving us the 5.1 Sound as well as the optional languages?
(2015-03-24, 16:18)mlu3141 Wrote: [ -> ]Oh. I saw the ability to add a single show or movie and thought that was all that was possible. (I'm hoping to add the entire collection.)
I dont think this is possible. It wouldn't be too convenient either since the content changes constantly.
For shows you can add seasons though instead of episodes.
(2015-03-25, 18:42)AlmostSerious Wrote: [ -> ]Does anybody know if its possible to trick Amazon into giving us the 5.1 Sound as well as the optional languages?
I don't know about Europe Amazon, but for US Amazon, 5.1 is not a available via the rtmp package. It is restricted to silverlight (for PCs) and various "set-top", dongle, and embedded-TV systems. Unlike netflix, US Amazon encrypts the silverlight 5.1 audio streams. The hurdle with silverlight being the private key. Silverlight probably wouldn't be practical for real-time decryption on the varied kodi hardware. Although I don't know if anyone has even tried.
So how about we all send the dev $10 or so?
It would definitely be worth it for me to get some of the fixable issues working.
My problem is that suddenly my login fails... Not sure what's causing the problem, works fine in the browser, but not through this app.
Is the code in GitHub or similar?
Cheers,
Dan.
not working here:
lubuntu trusty tah 14.04.2
kodi 14.2
was working before an update I did yesterday, of kodi and overall system, running 14.02 lubutnu before, btw
it runs ok, but fails to play anything
log in here http://xbmclogs.com/pl4kaoonv
tried the default.py new version from dropbox, and reinstalling the script
--- remarkable stuff in the log::
ERROR: CDVDPlayer::OpenInputStream - error opening [rtmp://azeufms-vodfs.fplive.net/azeufms-vod/mp4:lovefilm/lf/unencrypted/prod/1/0/5/1052b5e4-3ccd-40ce-ac47-809c96610135/d8c16a77-ca66-430a-ae1e-d7d381ffda13_video_480p_2000kbps_audio_aaclc_128kbps.mp4?nvb=20150329201123&nva=20150330061123&sessionId=16523-ea87d859-06dd-4f90-a720-ba7cecc1ab38&hash=1da28df2870512200f73d swfVfy=1 swfUrl=http://ecx.images-amazon.com/images/G/01/digital/video/streaming/169.0-0/UnboxScreeningRoomClient._V320644271_.swf pageUrl=http://www.amazon.co.uk/dp/B00M0D4IUI app=azeufms-vod playpath=mp4:lovefilm/lf/unencrypted/prod/1/0/5/1052b5e4-3ccd-40ce-ac47-809c96610135/d8c16a77-ca66-430a-ae1e-d7d381ffda13_video_480p_2000kbps_audio_aaclc_128kbps.mp4?nvb=20150329201123&nva=20150330061123&sessionId=16523-ea87d859-06dd-4f90-a720-ba7cecc1ab38&hash=1da28df2870512200f73d tcUrl=rtmpe://azeufms-vodfs.fplive.net:1935/azeufms-vod/]
and ....
20:25:16 T:2623613760 DEBUG: Addon script.module.amazon.database requires xbmc.python version 1.0 which is not available
20:26:03 T:2575301440 ERROR: Unable to load librtmp.so.1, reason: librtmp.so.1: cannot open shared object file: No such file or directory
20:26:03 T:2575301440 DEBUG: Dll librtmp.so.1 was not found in path
(2015-03-29, 23:14)killface Wrote: [ -> ]20:26:03 T:2575301440 ERROR: Unable to load librtmp.so.1, reason: librtmp.so.1: cannot open shared object file: No such file or directory
Mmmm have rtmp. .. apt-get and it is the latest,
I will try removing and reinstalling, if that doesn't work, I will do the manual compile and replace, though not very sure how to
did not spot that shame on me Tongue
Add-on appears to install and connect however it will not accept my Amazon login and password? When I normally login to Amazon, there is a CAPTCHA box so how is anyone able to login?
I have never ever seen CAPTCHA on amazon.
(2015-03-26, 19:22)toejam Wrote: [ -> ]
As I understood, the FireTV is using rtmp as well? And on FireTV there is 5.1.
(2015-03-30, 06:15)mr3p Wrote: [ -> ]Add-on appears to install and connect however it will not accept my Amazon login and password? When I normally login to Amazon, there is a CAPTCHA box so how is anyone able to login?
(warning: total newbie on kodi typing here)
I'm excited about seeing Prime on kodi, but prime won't accept my login and password either from the add-on.
Wife says she never sees captcha signing in to Amazon from her desktop.
Going back to regular webpage to login to my Amazon account, I only see CAPTCHA when I go into account settting, not just logging into site. That being said, the Amazon login/password which work fine with Chrome browser, do not allow me to login with this add-on as I get the error message in lower right corner, "You are not logged in! Check your credentials and restart the add-on..."
(2015-03-29, 23:27)oooh.oooh Wrote: [ -> ]
I had the same error log. Amazon Addon is working again after an apt-get install rtmp* for me
What exactly does the new default.py fix?
I too have issues playing certain things. Sometimes I get the ding and error, other times nothing happens on screen when playing a TV show/movie, bu in the logs I see "rtmp server sent error" regardless.
(2015-03-31, 09:33)tavoc Wrote: [ -> ]
Same issue here, apt-get install rtmp* does the job... Thanks for this!
