20:23:10 T:2169445184 NOTICE: https://www.amazon.co.uk/dp/B00FZQW7BE/?_encoding=UTF8
20:23:10 T:2993370944 DEBUG: DialogProgress::StartModal called
20:23:10 T:2993370944 DEBUG: ------ Window Init (DialogProgress.xml) ------
20:23:11 T:2169445184 NOTICE: https://atv-ps-eu.amazon.com/cdp/catalog/GetASINDetails?version=2&format=json&asinlist=B00FZQW7BE&deviceID=AMC0M2OBUPKAY&includeRestrictions=true&deviceTypeID=A35LWR0L7KC0TJ&firmware=WIN%2017,0,0,188%20PlugIn&NumberOfResults=1
20:23:12 T:2169445184 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'urllib2.HTTPError'>
Error Contents: HTTP Error 410: Gone
File "/home/atreyu/.kodi/addons/plugin.video.prime_instant/default.py", line 1463, in <module>
playVideo(url, selectQuality=="true")
File "/home/atreyu/.kodi/addons/plugin.video.prime_instant/default.py", line 786, in playVideo
asincontent = getUnicodePage('https://'+apiMain+'.amazon.com/cdp/catalog/GetASINDetails?version=2&format=json&asinlist='+videoID+'&deviceID='+urllib.quote_plus(matchCID[0].encode("utf8"))+'&includeRestrictions=true&deviceTypeID='+matchDID[0]+'&firmware=WIN%2017,0,0,188%20PlugIn&NumberOfResults=1')
File "/home/atreyu/.kodi/addons/plugin.video.prime_instant/default.py", line 1011, in getUnicodePage
req = opener.open(url)
File "/usr/lib/python2.7/urllib2.py", line 410, in open
response = meth(req, response)
File "/usr/lib/python2.7/urllib2.py", line 523, in http_response
'http', request, response, code, msg, hdrs)
File "/usr/lib/python2.7/urllib2.py", line 448, in error
return self._call_chain(*args)
File "/usr/lib/python2.7/urllib2.py", line 382, in _call_chain
result = func(*args)
File "/usr/lib/python2.7/urllib2.py", line 531, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 410: Gone
20:23:12 T:2993370944 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
20:23:12 T:2169445184 INFO: Python script stopped
20:23:12 T:2169445184 DEBUG: Thread LanguageInvoker 2169445184 terminating
20:23:12 T:2993370944 DEBUG: WaitOnScriptResult - plugin exited prematurely - terminating
20:23:12 T:2993370944 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.prime_instant/?url=B00FZQW7BE&mode=playVideo&name=John+Carter&thumb=https%3A%2F%2Fimages-eu.ssl-images-amazon.com%2Fimages%2FI%2F51FrG3hANLL.jpg]
20:23:12 T:2993370944 DEBUG: Playlist Player: one or more items failed to play... aborting playback
20:23:12 T:2993370944 DEBUG: ------ Window Init (DialogOK.xml) ------
20:23:12 T:2993370944 DEBUG: ------ Window Deinit (DialogProgress.xml) ------
20:23:14 T:2993370944 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x000d, modifier: 0x0
20:23:14 T:2993370944 DEBUG: OnKey: return (0xf00d) pressed, action is Select
20:23:15 T:2993370944 DEBUG: ------ Window Deinit (DialogOK.xml) ------
20:23:15 T:2993370944 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
20:23:15 T:2993370944 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
20:23:15 T:2169445184 NOTICE: Thread BackgroundLoader start, auto delete: false
20:23:15 T:2169445184 DEBUG: Thread BackgroundLoader 2169445184 terminating
