Full Version: [RELEASE] Amazon Prime Instant Video (US/UK/DE)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
Over the weekend, I could not get this to work on my ION unit running Openelec 5... I was only able to get 1 movie to play (it may have been Jack Ryan, but I am not sure)... all other videos either threw up an error, or got the 'waiting' animation (using confluence) and then dropped back to menu.
Since I do not have access to that log ATM, I installed the plugin on my laptop running Windows 8.1 to see if I got similar results.... and I cannot get anything to play at all.
Here is the log: http://pastebin.com/qAj1cP1k
(2015-01-21, 14:03)da-anda Wrote: [ -> ]Tested (watched an entire movie) yesterday on a WETEK Play box running OpenElec - worked like a charm. Awesome work dude - now the very same for Netflix please Smile
I'm still really curious how this is even possible!
AddonScriptor: I don't expect this to be integrated anytime soon, but do you think it would somehow be possible to add the possibility of buying movies outside the prime instant video offer using the addon?
I cannot make it work in Kodi installed in Linux (Kodibuntu). I understand that Chrome does not support Pipelight etc anymore. I cannot even stream Amazon Prime videos in straight-up Chrome browser outside of Kodi.
Does anyone have any advice on running Amazon prime inside Chrome?
I am running it on an updated XBMCbuntu. You have to use flash to run in in Chrome or in this plugin.
Change the settings in Amazon prime portal.
@topic
Is only me or does this plugin dont use the video cache? In the evening there is a lot of buffering when choosing the highest quality (I have a 50 Mbit landline)
(2015-01-22, 11:22)tavoc Wrote: [ -> ]@topic
Good question and I hope, somebody have an answer? But I think, this plugin doesn't use the video cache, because I cannot see something (video-content) cache-progress for this plugin. With the YouTube- or e.g. the ARTE-Plugin, I can see a cache-prozess.
Quote: In the evening there is a lot of buffering when choosing the highest quality (I have a 50 Mbit landline)
Your landline is too slow, for the highest quality!
The highest quality is 1080p with 10 MB/s (12.500 kB/s = 100.000 Bit/s). Your landline has "only" 50MBit/s (6250 kB/s = 50.000 Bit/s). You can try e.g. the quality 720p with 6000 kB/s.
(2015-01-22, 18:51)kar82 Wrote: [ -> ]Your landline is too slow, for the highest quality!
It's 10Mbps (Mbit not Mbyte per second). A 50Mbit line should be more than enough to stream 1080p content.
(2015-01-22, 19:27)PhunkMaZ Wrote: [ -> ]A 50Mbit line should be more than enough to stream 1080p content.
No, the connection is up to 50Mbit, there is no guarantee that you will recieve this speed.
Hulu/Nettflix is not possible.
(2015-01-21, 09:14)tavoc Wrote: [ -> ]Installed yesterday and bought today Amazon Prime. Finally a legal Stream integration for my Media Center. Awesome
I think this could be the future for kodi and other media centre software - imagine if you have an account with Netflix, Amazon, Sky go, Hulu etc and you can access them all easily via kodi and add the films and shows you like to your library. Instead of having to visit each site etc, you just load kodi, pick what you want to watch and away you go.
I hope someone can do something like this for Netflix and Sky go
Hello,
@AddonscriptorDE: is it possible to store the AMAZON Login in a crypted format and use a four number pin to start the addon?
I don't would line to save my password in plain. But I don't would like to type in so much each time.
Thanks and regards
kaminkehrer
It kind of works on Android but not every video plays. Anyone knows a fix ?Smile
(2015-01-21, 19:39)sdsnyr94 Wrote: [ -> ]Over the weekend, I could not get this to work on my ION unit running Openelec 5... I was only able to get 1 movie to play (it may have been Jack Ryan, but I am not sure)... all other videos either threw up an error, or got the 'waiting' animation (using confluence) and then dropped back to menu.
Similar issues... some vids play, some don't... movies and episodes.
21:11:33 T:2740  NOTICE: DVDPlayer: Opening: rtmp://amazon-584.fcod.llnwd.net/a397/d31/h264/HD/oscillo/6/105/75c55629-8dc3-43c3-863b-d864a09abaeb-584.mp4?e=1422112153&amz_s=16458-2bd0e942-fe47-45aa-81f6-402509e63017&h=9e31e32efc397186f88030f284ffe3e8 swfVfy=1 swfUrl=http://ecx.images-amazon.com/images/G/01/digital/video/streaming/169.0-0/UnboxScreeningRoomClient._V320644271_.swf pageUrl=http://www.amazon.com/dp/B006UQ5CPQ app=azusfms-vod playpath=8 tcUrl=rtmpe://azusfms-vodfs.fplive.net:1935/azusfms-vod/
21:11:33 T:2740 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
21:11:33 T:676  NOTICE: Thread DVDPlayer start, auto delete: false
21:11:33 T:676  NOTICE: Creating InputStream
21:11:34 T:676   ERROR: rtmp server sent error
21:11:34 T:676   ERROR: rtmp server requested close
21:11:34 T:676   ERROR: CDVDPlayer::OpenInputStream - error opening [rtmp://amazon-584.fcod.llnwd.net/a397/d31/h264/HD/oscillo/6/105/75c55629-8dc3-43c3-863b-d864a09abaeb-584.mp4?e=1422112153&amz_s=16458-2bd0e942-fe47-45aa-81f6-402509e63017&h=9e31e32efc397186f88030f284ffe3e8 swfVfy=1 swfUrl=http://ecx.images-amazon.com/images/G/01/digital/video/streaming/169.0-0/UnboxScreeningRoomClient._V320644271_.swf pageUrl=http://www.amazon.com/dp/B006UQ5CPQ app=azusfms-vod playpath=8 tcUrl=rtmpe://azusfms-vodfs.fplive.net:1935/azusfms-vod/]
21:11:34 T:676  NOTICE: CDVDPlayer::OnExit()
21:11:34 T:2740   ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.prime_instant/?url=B006UQ5CPQ&mode=playVideo&name=Howl&thumb=https%3A%2F%2Fimages-na.ssl-images-amazon.com%2Fimages%2FI%2F51Wzo6aoQAL.jpg]
Hello,
I found out that the password will be stored in a cookie.
The password is already encrypted.
Therefore I was wrong and I see no need for a change.
Thx
Regards
kaminkehrer
(2015-01-23, 05:13)locoguano Wrote: [ -> ]
Same issue with US version, don't work many movies and series. For example i have same log rtmp is initialitaze but fails with The Wolf, Catching Fire - Hunger games, Game of trones. But there are more filsm that don't work than films that Works. Anyway Thanks a lot for your effort. Thanks.
(2015-01-23, 19:20)netamego Wrote: [ -> ]
Yea I wonder why that happens same here! bunch of movies played but some simply didn't lol.
