2015-01-17, 08:26
OS X 10.10.1, iMac 11.3, Kodi 14.0 Git:2014-12-23-ad747d9-dirty
I'm having an issue with being able to play sound with 5.1 channels in Kodi 14.0. I am using USB Sound Blaster OMNI Surround 5.1. It took awhile to find the right settings in Frodo 12.3, but found in Kodi no matter what I try I only get 2 channels. If I set to 5.1 channels files will not play (like pause with slow motion frame advance) In Frodo 12.3 the key setting that changed it from 2 channels to 5.1 channels was -Multichannel LPCM capable receiver. No such setting exist is Kodi 14.0. On Mac Audio MIDI setup SB Omni Surround 5.1 output speaker configuration is set to 5.1 channel surround. (this changes to stereo or 5.1ch with the OMNI Surround 5.1 control panel setting). Also Kodi 14.0 will force this to stereo when I start to play a AC3 or DTS 5.1 channel Movie.
Kodi 14.0 Audio settings:
Output device: Default, SB Omni Surround 5.1
Number of channels: 2.0 ( anything else doesn't play)
Output configuration: Optimised, Best Match, Fixed (tried them all) N/C
Stereo upmix: N/C
Maintain original volume on downmix: N/C
Play GUI sounds: N/C
Enable passthrough (Tried Yes and No) N/C
Passthrough output device: Default, SB Omni Surround 5.1
Dolby Digital (AC3) capable receiver: No
DTS capable receiver: No
In Frodo 12.3 this was my Audio Output setting that works.
Audio Output: HDMI (odd for USB, but works. Analog selection mixed rear channels with front.)
Speaker Configuration: 2.0
Boost volume level on downmix: No
Output stereo to all speakers: No
-Dolby Digital (AC3) capable receiver: No
-DTS capable receiver: No
-Multichannel LPCM capable receiver: Yes
Audio output device: default
Stereo upmix: N/C
