Full Version: Very slow channel changing in latest OE builds
popcornmix Online
Team-Kodi Member
Today 13:47 Post: #269
(Today 13:31)pootler Wrote:
It is seen in these latest builds, but for some reason, these latest builds have ( for me ) a really really slow channel change which makes it difficult to use.
Also ( I am using VDR ), w_scan does not seem to find HD channels.
This is openelec on RPI, by the way
--REPLY ( popcornmix)
If the channel switch time got slower 21 days ago, then it's probably this:
https://github.com/xbmc/xbmc/pull/6036
Note this needs a fix to report the correct mime type in the PVR add-on, so best report the issue in the PVR add-on thread.
Has VDR fixed the correct mime type for this?
Manythanks
pootler
VNSI has its own demuxer and is certainly not affected by the linked PR.
(2015-01-18, 19:15)FernetMenta Wrote: [ -> ]VNSI has its own demuxer and is certainly not affected by the linked PR.
Thanks fernetmenta- problem must be elsewhere?
As an aside, I am using an August t210 dvb t2 tuner ( V2)
otherwise seen as geniatech t203.
because of this slow channel changing I am using it in a patched build of the earlier ( 3.17) kernel.
works fine, but w_scan cannot find any HD channels.?
this thread - http://openelec.tv/forum/71-pvr-live-tv/...mitstart=0 - points to (possibly) some possible problem with the search protocol?
Have you had any reports of this using VDR?
Many thanks
pootler
