2015-01-19, 02:13
Hi all
I couldn't quite find a file renamer for what I wanted (single file per movie, no art or NFO files you seem to get with media managers, etc.), so I've knocked one up for my purposes. I've put it on github in case anyone else is interested in using it: https://github.com/kwirk/kodi-file-renamer
Basically, it takes the library information from the Kodi MyVideos database file (i.e. .kodi/userdata/Database/MyVideosXX.db), and renames files to a standard naming convention. It also updates the database so Kodi still points to the correct file.
Only tested on Kodi Helix (MyVideos90.db) on Linux, but may work on other versions and operating systems. Also only tested on ext file system, so may end up with a few invalid file/folder name characters for other file systems (e.g. FAT, NTFS); although this should be easy to fix (see string replacement in code for "/" character). Only tested with basic file layout, and I don't expect it will work with anything complex (e.g. stacked files).
