Hello,
I was wonder if it was possible either through XML or python to create a list container that contains another list. Basically, I would like to create a skin/script that will display a vertical list of movie genres, and under each genre a horizontal list of movies in that genre. (Similar to how Roku displays netflix movies)
If there is not support for a list inside of a list. Is there a possible workaround?
Thank you for the help,
Ryan
You could use a grouplist filled with groups for each genre containing a label (the genre) and a container (list, wraplist, etc) with dynamic content pointing to a smart playlist. You may be able to point the content to the genre path (videodb://movies/genre/[id]) but then you need to know the id number for each genre.
Perhaps someone else could think of a easier way. Might be able to get you started though.
I think the 2D-list should be doable, but the question is how you will supply content for each genre sub-list.
For this you will need to think about a script or use preconfigured smartplaylists - assuming the genre list is static.
I was planning on using a script as well to grab all the possible Genres and each movie as well. I have a python dictionary defied with the genre as the key and the videos as the elements. I think where I am running into trouble is the XML code for the layout. Is it valid to have a list control and then another list under the itemlayout? For example:
<control type="list" id=101>
<description>Genre List Container</description>
<left>0</left>
<top>20</top>
<width>1280</width>
<height>380</height>
<visible>true</visible>
<viewtype>list</viewtype>
<orientation>vertical</orientation>
<pagecontrol>25</pagecontrol>
<scrolltime tween="sine" easing="out">200</scrolltime>
<autoscroll>false</autoscroll>
<itemlayout width="1240" height="172">
<control type="list" id=102>
<description>Video List Container</description>
<left>0</left>
<top>35</top>
<width>1240</width>
<height>172</height>
<orientation>horizontal</orientation>
<itemlayout width="100" height="172">
<control type="label">
<left>0</left>
<top>0</top>
<width>100</width>
<font>font14</font>
<selectedcolor>green</selectedcolor>
<label>$INFO[ListItem.Label2]</label>
</control>
</itemlayout>
<focusedlayout width="100" height="172">
</control>
</itemlayout>
</control>
I was assuming that a list container can only hold labels and images.
The idea of a grouplist for genres would work, but the genres aren't static so I don't really know how many genre's there will be.
Thank you,
Ryan
You would do something like this (I'm using pseudo-code here but it should be easy enough to adapt to your purpose):
<control type="grouplist">
<!--Genre 1-->
<control type="group" id="1000">
<visible>IntegerGreaterThan($INFO[Container([id of the list below]).NumItems)],0)</visible> <!--This will hide the group if the genre container doesn't have any movies in it.-->
<control type="label" id="1100">
</control>
<control type="list" id="1200"> <!--This is the container that will hold of the movies that have this genre-->
<onup>[previous list id]</onup>
<ondown>[next list id]</ondown>
<onright>1200</onright>
<itemlayout>
</itemlayout>
<focusedlayout>
</focusedlayout>
<content type="video">plugin://[this is where you grab the dynamic content supplied by your script</content>
</control>
</control>
<!--Rinse and repeat the above group for as many genres you think you might need-->
</control>
What you are trying to implement is actually veryeasy.
you need to use the dynamic list content capabilty of the skin engine
Aadd a new list to the movie genres window and have the new list be filled with the following content tag
<content>$INFO[ListItem.DBID,videodb://movies/genres/,]</content>
