Full Version: adding VLC as a external player
Hello I am interested in adding the vlc player as a external player in xbmc. I haave went to the Kodi Wiki on this
external_players (wiki)
I see in the wiki it tells about the script
<playercorefactory>
<players>
   <player name="MPC-HC" type="ExternalPlayer" audio="false" video="true">
     <filename>C:\Program Files\MPC-HC\mplayerc.exe</filename>
     <args>"{1}" /fullscreen /close</args>
     <hidexbmc>false</hidexbmc>
     <hideconsole>false</hideconsole>
     <warpcursor>none</warpcursor>
   </player>
</players>
<rules action="prepend">
   <rule filetypes="mkv" filename=".*720p.*" player="MPC-HC"/>
</rules>
</playercorefactory>
it also tells about this
<rule video="true" player="wmplayer">
   <rule dvd="true" player="dvdplayer"/>
   <rule filetypes="mkv" player="VLC">
     <rule filename=".*720.*|.*1080.*" player="MPC-HC"/>
   </rule>
</rule>
</rules>
now here is my playercorefactory script
<?xml version="1.0" encoding="UTF-8"?>
<playercorefactory>
  <players>
    <!-- These are compiled-in as re-ordering them would break scripts
    The following aliases may also be used:
      audiodefaultplayer, videodefaultplayer, videodefaultdvdplayer
    <player name="DVDPlayer" audio="true" video="true" />
    <player name="DVDPlayer" /> placeholder for MPlayer
    <player name="PAPlayer" audio="true" />
  </players>
  <rules name="system rules">
    <rule name="rtv" protocols="rtv" player="DVDPlayer" />
    <rule name="hdhomerun/myth/mms/udp" protocols="hdhomerun|myth|cmyth|mms|mmsh|udp" player="DVDPlayer" />
    <rule name="lastfm/shout" protocols="lastfm|shout" player="PAPlayer" />
    <rule name="rtmp" protocols="rtmp" player="videodefaultplayer" />
    <!-- dvdplayer can play standard rtsp streams -->
    <rule name="rtsp" protocols="rtsp" filetypes="!(rm|ra)"  player="PAPlayer" />
    <!-- Internet streams -->
    <rule name="streams" internetstream="true">
      <rule name="aacp/sdp" mimetypes="audio/aacp|application/sdp" player="DVDPlayer" />
      <rule name="mp2" mimetypes="application/octet-stream" filetypes="mp2" player="PAPlayer" />
    </rule>
    <!-- DVDs -->
    <rule name="dvd" dvd="true" player="DVDPlayer" />
    <rule name="dvdimage" dvdimage="true" player="DVDPlayer" />
    <!-- Only dvdplayer can handle these normally -->
    <rule name="sdp/asf" filetypes="sdp|asf" player="DVDPlayer" />
    <!-- Pass these to dvdplayer as we do not know if they are audio or video -->
    <rule name="nsv" filetypes="nsv" player="DVDPlayer" />
    <!-- pvr radio channels should be played by dvdplayer because they need buffering -->
    <rule name="radio" filetypes="pvr" filename=".*/radio/.*" player="DVDPlayer" />
  </rules>
but i am not exactly straight on how to change this so can someone direct me on what i need to do?
tks in advance.
david
