2016-10-30, 09:38
(2016-10-30, 02:49)blueeyiz702 Wrote: [ -> ](2015-11-12, 21:35)ProRipp Wrote: [ -> ]Post your suggestions ! If I can't get round to it in between my duties on Fanart.TV etc I will try, otherwise I'm sure someone will step in.
You need to get over to Fanart.TV forums to register interest in opening a new section for motion posters there. The more people ask the more likely it will be that a section gets opened ! Click the link for info.
Opening Sections On Fanart.TV
So what did they end up saying about the idea?
Post 324: http://forum.kodi.tv/showthread.php?tid=...pid2194362
Quote:How many frames go into these gifs?Fanart.tv link: https://forum.fanart.tv/viewtopic.php?f=20&t=416
While I wouldn't want gifs on the fanart.tv site, what I would consider is if there were full size posters (jpgs) with say up to 120 frames.
Then we could reduce them down to a specific size and generate an animated gif from that, that would mean if a better option came about later (webp maybe) we could use that from the original frames directly, it would also be possible to create the same affect with css, by defining all the keyframes and animating it.
