2015-01-23, 12:13
When I play on Macbook Air using the thunder bolt to HDMI to display on the TV, everything is just fine in XBMC.
However, when I play on Mac mini, there are a few stutters in mkv files playback but audio works fine.
I try to tap on the 'o' button to see the info during the playback
I observe that there is a sudden drop in fps(like 24fps to 18.xfps) when there is stutter.
May I know how to fix the problem and what cause the stutter? Thanks
Specification:
Mac mini(late 2014)
2.6Ghz Intel Core i5
8GB 1600 MHz DDR3 ram
Intel Iris 1536mb
XBMC 13.2 (compiled: Aug 17 2014)
Mac OS X 10.10.1
Macbook Air
1.3Ghz Intel Core i5
Intel HD Graphics 5000 1536MB
XBMC 13.2 (compiled:Aug 17 2014)
Mac OS X 10.10.1
debug log of Mac Mini
[/quote]
Specification:
Mac mini(late 2014)
Intel Iris 1536mb
Mac OS X 10.10.1
Macbook Air
Mac OS X 10.10.1
11:00:43 T:140735309505280 NOTICE: special://profile/ is mapped to: special://masterprofile/
11:00:43 T:140735309505280 NOTICE: -----------------------------------------------------------------------
11:00:43 T:140735309505280 NOTICE: Starting XBMC (13.2 Git:20140817-0f3db05). Platform: x86 Darwin OSX 64-bit
11:00:43 T:140735309505280 NOTICE: Using Unknown XBMC x64 build, compiled Aug 17 2014 by Clang 4.2.0 for x86 Darwin OSX 64-bit version 1060
11:00:43 T:140735309505280 NOTICE: Running on Darwin OSX 64-bit 14.0.0 x86_64, Version 10.10.1 (Build 14B25)
11:00:43 T:140735309505280 NOTICE: Host CPU: Intel(R) Core(TM) i5-4278U CPU @ 2.60GHz, 4 cores available
11:00:43 T:140735309505280 NOTICE: special://xbmc/ is mapped to: /Applications/XBMC.app/Contents/Resources/XBMC
11:00:43 T:140735309505280 NOTICE: special://xbmcbin/ is mapped to: /Applications/XBMC.app/Contents/Resources/XBMC
11:00:43 T:140735309505280 NOTICE: special://masterprofile/ is mapped to: /Users/Angus/Library/Application Support/XBMC/userdata
11:00:43 T:140735309505280 NOTICE: special://home/ is mapped to: /Users/Angus/Library/Application Support/XBMC
11:00:43 T:140735309505280 NOTICE: special://temp/ is mapped to: /Users/Angus/.xbmc/temp
11:00:43 T:140735309505280 NOTICE: special://frameworks/ is mapped to: /Applications/XBMC.app/Contents/Libraries
11:00:43 T:140735309505280 NOTICE: The executable running is: /Applications/XBMC.app/Contents/MacOS/XBMC
11:00:43 T:140735309505280 NOTICE: Local hostname: Poks-Mac-mini.local
11:00:43 T:140735309505280 NOTICE: Log File is located: /Users/Angus/Library/Logs/xbmc.log
11:00:43 T:140735309505280 NOTICE: load settings...
11:00:43 T:140735309505280 ERROR: Unable to load libcrystalhd.dylib, reason: dlopen(libcrystalhd.dylib, 1): image not found
11:00:43 T:140735309505280 NOTICE: Found 1 Lists of Devices
11:00:43 T:140735309505280 NOTICE: Enumerated DARWINOSX devices:
11:00:43 T:140735309505280 NOTICE: Device 1
11:00:43 T:140735309505280 NOTICE: m_deviceName : default
11:00:43 T:140735309505280 NOTICE: m_displayName : Default
11:00:43 T:140735309505280 NOTICE: m_displayNameExtra:
11:00:43 T:140735309505280 NOTICE: m_deviceType : AE_DEVTYPE_PCM
11:00:43 T:140735309505280 NOTICE: m_channels : FL,FR
11:00:43 T:140735309505280 NOTICE: m_sampleRates : 96000,88200,48000,44100
11:00:43 T:140735309505280 NOTICE: m_dataFormats : AE_FMT_S24LE3,AE_FMT_S16LE,AE_FMT_FLOAT
11:00:43 T:140735309505280 NOTICE: Device 2
11:00:43 T:140735309505280 NOTICE: m_deviceName : AirPlay
11:00:43 T:140735309505280 NOTICE: m_displayName : AirPlay
11:00:43 T:140735309505280 NOTICE: m_sampleRates : 44100
11:00:43 T:140735309505280 NOTICE: m_dataFormats : AE_FMT_S16LE
11:00:43 T:140735309505280 NOTICE: Device 3
11:00:43 T:140735309505280 NOTICE: m_deviceName : Built-in Output
11:00:43 T:140735309505280 NOTICE: m_displayName : Built-in Output
11:00:43 T:140735309505280 NOTICE: Device 4
11:00:43 T:140735309505280 NOTICE: m_deviceName : HDMI
11:00:43 T:140735309505280 NOTICE: m_displayName : HDMI
11:00:43 T:140735309505280 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
11:00:43 T:140735309505280 NOTICE: m_sampleRates : 192000,176400,96000,88200,48000,44100,32000
11:00:43 T:140735309505280 NOTICE: m_dataFormats : AE_FMT_S24LE3,AE_FMT_EAC3,AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS
11:00:43 T:140735309505280 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
11:00:43 T:140735309505280 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
11:00:43 T:140735309505280 NOTICE: Default DVD Player: dvdplayer
11:00:43 T:140735309505280 NOTICE: Default Video Player: dvdplayer
11:00:43 T:140735309505280 NOTICE: Default Audio Player: paplayer
11:00:43 T:140735309505280 NOTICE: Disabled debug logging due to GUI setting. Level 0.
11:00:43 T:140735309505280 NOTICE: Log level changed to 0
11:00:43 T:140735309505280 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
11:00:43 T:140735309505280 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
11:00:43 T:140735309505280 NOTICE: Loaded playercorefactory configuration
11:00:43 T:140735309505280 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
11:00:43 T:140735309505280 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
11:00:43 T:4494258176 NOTICE: Thread ActiveAE start, auto delete: false
11:00:43 T:4494794752 NOTICE: Thread AESink start, auto delete: false
11:00:43 T:4494794752 NOTICE: virtual bool CAESinkDARWINOSX::Initialize(AEAudioFormat &, std::string &): Opening default device Built-in Output
11:00:43 T:140735309505280 NOTICE: Running database version Addons16
11:00:43 T:140735309505280 NOTICE: ADDONS: Using repository repository.xbmc.org
11:00:43 T:140735309505280 NOTICE: ADDONS: Using repository repository.pvr-osx64.xbmc.org
11:00:43 T:4497457152 NOTICE: Thread PeripBusCEC start, auto delete: false
11:00:43 T:140735309505280 NOTICE: Setup SDL
11:00:43 T:140735309505280 NOTICE: Display 0 has name 47PFL7482
11:00:43 T:140735309505280 NOTICE: Found possible resolution for display 0 with 1920 x 1080 @ 59.875031 Hz
11:00:43 T:140735309505280 NOTICE: Found possible resolution for display 0 with 1280 x 768 @ 59.875031 Hz
11:00:43 T:140735309505280 NOTICE: Found possible resolution for display 0 with 640 x 480 @ 59.875031 Hz
11:00:43 T:140735309505280 NOTICE: Found possible resolution for display 0 with 720 x 480 @ 59.875031 Hz
11:00:43 T:140735309505280 NOTICE: Found possible resolution for display 0 with 1280 x 720 @ 60.000015 Hz
11:00:43 T:140735309505280 NOTICE: Found possible resolution for display 0 with 1920 x 1080 @ 60.000015 Hz
11:00:43 T:140735309505280 NOTICE: Found possible resolution for display 0 with 720 x 576 @ 50.000015 Hz
11:00:43 T:140735309505280 NOTICE: Found possible resolution for display 0 with 1280 x 720 @ 50.000015 Hz
11:00:43 T:140735309505280 NOTICE: Found possible resolution for display 0 with 1920 x 1080 @ 50.000015 Hz
11:00:43 T:140735309505280 NOTICE: Found possible resolution for display 0 with 800 x 600 @ 60.000015 Hz
11:00:43 T:140735309505280 NOTICE: Found possible resolution for display 0 with 1024 x 768 @ 60.000015 Hz
11:00:43 T:140735309505280 NOTICE: Found possible resolution for display 0 with 1024 x 576 @ 60.000015 Hz
11:00:43 T:140735309505280 NOTICE: Found possible resolution for display 0 with 1280 x 960 @ 60.000015 Hz
11:00:43 T:140735309505280 NOTICE: Found possible resolution for display 0 with 1344 x 1008 @ 60.000015 Hz
11:00:43 T:140735309505280 NOTICE: Found possible resolution for display 0 with 1344 x 756 @ 60.000015 Hz
11:00:43 T:140735309505280 NOTICE: Found possible resolution for display 0 with 1600 x 900 @ 60.000015 Hz
11:00:43 T:140735309505280 NOTICE: Checking resolution 16
11:00:43 T:140735309505280 NOTICE: GL_VENDOR = Intel Inc.
11:00:43 T:140735309505280 NOTICE: GL_RENDERER = Intel Iris OpenGL Engine
11:00:43 T:140735309505280 NOTICE: GL_VERSION = 2.1 INTEL-10.0.86
11:00:43 T:140735309505280 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
11:00:43 T:140735309505280 NOTICE: GL_EXTENSIONS = GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_barrier GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
11:00:44 T:140735309505280 NOTICE: No Joystick name specified, loading default map
11:00:44 T:140735309505280 NOTICE: Previous line repeats 35 times.
11:00:44 T:140735309505280 NOTICE: Running database version Addons16
11:00:44 T:140735309505280 NOTICE: Running database version ViewModes6
11:00:44 T:140735309505280 NOTICE: Running database version Textures13
11:00:44 T:140735309505280 NOTICE: Running database version MyMusic46
11:00:44 T:140735309505280 NOTICE: Running database version MyVideos78
11:00:44 T:140735309505280 NOTICE: Running database version TV22
11:00:44 T:140735309505280 NOTICE: Running database version Epg7
11:00:44 T:140735309505280 NOTICE: start dvd mediatype detection
11:00:44 T:4559155200 NOTICE: Thread DetectDVDMedia start, auto delete: false
11:00:44 T:140735309505280 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
11:00:44 T:140735309505280 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
11:00:44 T:4561158144 NOTICE: Thread LanguageInvoker start, auto delete: false
11:00:44 T:140735309505280 NOTICE: initialize done
11:00:44 T:4561158144 NOTICE: -->Python Interpreter Initialized<--
11:00:44 T:140735309505280 NOTICE: Running the application...
11:00:44 T:4591067136 NOTICE: Thread JobWorker start, auto delete: true
11:00:44 T:140735309505280 NOTICE: starting zeroconf publishing
11:00:44 T:140735309505280 NOTICE: ES: Starting event server
11:00:44 T:4591603712 NOTICE: Thread JobWorker start, auto delete: true
11:00:44 T:4592140288 NOTICE: Thread EventServer start, auto delete: false
11:00:44 T:4592140288 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
11:00:44 T:4592140288 NOTICE: UDP: Listening on port 9777
11:00:44 T:4592676864 NOTICE: Thread TCPServer start, auto delete: false
11:00:44 T:4572385280 NOTICE: Thread RSSReader start, auto delete: false
11:01:43 T:4495331328 WARNING: DARWINOSX: underflow (0 vs 4096 bytes)
11:02:13 T:4375191552 NOTICE: Thread JobWorker start, auto delete: true
11:02:19 T:4376436736 NOTICE: Thread BackgroundLoader start, auto delete: false
11:02:27 T:140735309505280 NOTICE: Previous line repeats 3 times.
11:02:27 T:140735309505280 NOTICE: DVDPlayer: Opening: smb://READYSHARE/USB_Storage/Movie/Lets.Be.Cops.2014.BluRay.720p.DTS.x264-CHD/Lets.Be.Cops.2014.BluRay.720p.DTS.x264-CHD.mkv
11:02:27 T:140735309505280 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
11:02:27 T:4591411200 NOTICE: Thread DVDPlayer start, auto delete: false
11:02:27 T:4591411200 NOTICE: Creating InputStream
11:02:27 T:4591411200 NOTICE: Creating Demuxer
11:02:27 T:4591411200 NOTICE: Opening video stream: 0 source: 256
11:02:27 T:4591411200 NOTICE: Creating video codec with codec id: 28
11:02:27 T:4591411200 NOTICE: Creating video thread
11:02:27 T:4634411008 NOTICE: Thread DVDPlayerVideo start, auto delete: false
11:02:27 T:4634411008 NOTICE: running thread: video_thread
11:02:27 T:4591411200 NOTICE: Opening audio stream: 1 source: 256
11:02:27 T:4591411200 NOTICE: Finding audio codec for: 86020
11:02:27 T:4591411200 NOTICE: Creating audio thread
11:02:27 T:4634947584 NOTICE: Thread DVDPlayerAudio start, auto delete: false
11:02:27 T:4634947584 NOTICE: running thread: CDVDPlayerAudio::Process()
11:02:27 T:4591411200 NOTICE: Opening Subtitle stream: 0 source: 1024
11:02:28 T:4634947584 NOTICE: Creating audio stream (codec id: 86020, channels: 6, sample rate: 48000, no pass-through)
11:02:28 T:4494794752 NOTICE: virtual bool CAESinkDARWINOSX::Initialize(AEAudioFormat &, std::string &): Opening default device Built-in Output
11:02:28 T:4634411008 NOTICE: fps: 23.976024, pwidth: 1280, pheight: 690, dwidth: 1280, dheight: 690
11:02:28 T:4634411008 NOTICE: Display resolution DESKTOP : 1920x1080@ 60.00 - Full Screen (16)
11:02:28 T:140735309505280 NOTICE: Using GL_TEXTURE_2D
11:02:28 T:140735309505280 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
11:02:28 T:140735309505280 NOTICE: GL: NPOT texture support detected
11:02:35 T:4591411200 NOTICE: Closing subtitle stream
11:02:35 T:4591411200 NOTICE: Opening Subtitle stream: 0 source: 1024
11:10:37 T:4667076608 NOTICE: Thread BackgroundLoader start, auto delete: false
11:10:41 T:4667813888 NOTICE: Thread JobWorker start, auto delete: true
11:13:22 T:140735309505280 NOTICE: Storing total System Uptime
11:13:22 T:140735309505280 NOTICE: Saving settings
11:13:22 T:140735309505280 NOTICE: stop all
11:13:22 T:140735309505280 NOTICE: stop player
11:13:22 T:140735309505280 NOTICE: CDVDPlayer::CloseFile()
11:13:22 T:140735309505280 NOTICE: DVDPlayer: waiting for threads to exit
11:13:22 T:4591411200 NOTICE: CDVDPlayer::OnExit()
11:13:22 T:4591411200 NOTICE: DVDPlayer: closing audio stream
11:13:22 T:4591411200 NOTICE: Closing audio stream
11:13:22 T:4591411200 NOTICE: Waiting for audio thread to exit
11:13:22 T:4634947584 NOTICE: thread end: CDVDPlayerAudio::OnExit()
11:13:22 T:4591411200 NOTICE: Closing audio device
11:13:22 T:4591411200 NOTICE: Deleting audio codec
11:13:22 T:4591411200 NOTICE: DVDPlayer: closing video stream
11:13:22 T:4591411200 NOTICE: Closing video stream
11:13:22 T:4591411200 NOTICE: waiting for video thread to exit
11:13:22 T:4634411008 NOTICE: thread end: video_thread
11:13:22 T:4591411200 NOTICE: deleting video codec
11:13:22 T:4591411200 NOTICE: DVDPlayer: closing subtitle stream
11:13:22 T:4591411200 NOTICE: Closing subtitle stream
11:13:22 T:4591411200 NOTICE: CDVDPlayer::OnExit() deleting demuxer
11:13:22 T:4591411200 NOTICE: CDVDPlayer::OnExit() deleting input stream
11:13:22 T:140735309505280 NOTICE: DVDPlayer: finished waiting
11:13:22 T:140735309505280 NOTICE: ES: Stopping event server
11:13:22 T:140735309505280 NOTICE: stopping zeroconf publishing
11:13:22 T:4494794752 NOTICE: virtual bool CAESinkDARWINOSX::Initialize(AEAudioFormat &, std::string &): Opening default device Built-in Output
11:13:22 T:4592140288 NOTICE: ES: UDP Event server stopped
11:13:22 T:140735309505280 NOTICE: stop dvd detect media
11:13:22 T:140735309505280 NOTICE: stop sap announcement listener
11:13:22 T:140735309505280 NOTICE: clean cached files!
11:13:22 T:140735309505280 NOTICE: unload skin
11:13:22 T:140735309505280 WARNING: Cleanup: Having to cleanup texture button-focus.png
11:13:22 T:140735309505280 WARNING: Cleanup: Having to cleanup texture button-nofocus.png
11:13:22 T:140735309505280 NOTICE: stopped
11:13:22 T:140735309505280 NOTICE: destroy
11:13:22 T:140735309505280 NOTICE: unload sections
11:13:22 T:140735309505280 NOTICE: special://profile/ is mapped to: special://masterprofile/
11:13:23 T:140735309505280 NOTICE: destroy
11:13:23 T:140735309505280 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
11:13:23 T:140735309505280 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
11:13:23 T:140735309505280 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
11:13:23 T:140735309505280 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
11:13:23 T:140735309505280 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
11:13:23 T:140735309505280 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
11:13:23 T:140735309505280 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
11:13:23 T:140735309505280 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
11:13:23 T:140735309505280 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
11:13:23 T:140735309505280 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
11:13:23 T:140735309505280 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
11:13:23 T:140735309505280 NOTICE: unload sections
11:13:23 T:140735309505280 NOTICE: application stopped...
