2015-02-10, 20:41
2015-02-11, 00:21
So here is the new version:
https://dl.dropboxusercontent.com/u/1877...-0.0.2.zip
https://dl.dropboxusercontent.com/u/1877...0.0.05.zip
You need to install both (sportscenter and module.thesportsdb).
Changelog:
-Fixed a few issues
-Added navigation to leagues
Notes:
-League tables are not available in the db so, not implemented.
-News feeds are not available in the db so, it's a fixed view.
-Video section is listing the nba channel for every single league since users haven't yet filled the youtube channel of each league.
-League navigation is only available for Nox and Mimic. I'll port it now to confluence.
Cheers and hope u enjoy
Changelog:
-Fixed a few issues
Notes:
2015-02-11, 16:55
wow!
I'll try that great news Enen
2015-02-11, 17:10
I see that still need to finish ...
Enen if you want help, I volunteer to translate the texts into Spanish.
2015-02-11, 17:33
Any particular format you would like the league tables in mate?
2015-02-11, 17:46
@enen92 - looks awesome! One question - is it possible to follow a certain team/division/league to receive only the updates that one may be interested in?
2015-02-11, 18:08
(2015-02-11, 17:46)bry- Wrote: [ -> ]@enen92 - looks awesome! One question - is it possible to follow a certain team/division/league to receive only the updates that one may be interested in?
It's planed to have a favourites entry in the menu that will list only teams and leagues you follow and also to hide leagues/sports you don't follow from the listings. For instance, I don't want to follow: poland, norway, ukrania, china, australia, etc
2015-02-11, 18:09
(2015-02-11, 17:10)Laser78 Wrote: [ -> ]I see that still need to finish ...
Thanks, translations are not yet available but are pretty easy to make. I'll try to use the new strings.po format since strings.xml is now deprecated.
Note that appart from finishing the code and the dialogs most of the work on this is on the db side. We need high quality artwork, info, fixtures/events. Check the database at www.thesportsdb.com.
In fact I think ovokx has already filled lot of stuff in spanish there.
It might be a good idea for you to post the news (not this addon but the existing database) on your blog to inspirate people to contribute. I'll try to keep adding stuff but it's a waste of effort from my side. Most of the stuff is wikipedia and links.
2015-02-11, 18:13
(2015-02-11, 17:33)zag Wrote: [ -> ]Any particular format you would like the league tables in mate?
If you can pull this data: http://web.ist.utl.pt/~ist157804/zag/ptp...tables.csv it would be cool (points, games played/wins/losts/draws/Goals scored/goals conceeded/goal difference).
Return a list containing dictionaries for each team ordered by position/points from the higher to the lower. each team dictionary should have:
-teamid
-teamname
-points
-# games played
-Losts
-wins
-draws
-goals scored
-goals conceeded
-goal difference
Something like:
: [{teamid:452345435,teamname:Chelsea, points: 32, ...},{teamid: 23123,teamname: Mancity, points:20,...}]
2015-02-11, 19:33
2015-02-11, 20:20
I'm getting a blank page when I click on a league, is that supposed to be happening?
Using Aeon nox 5
Using Aeon nox 5
2015-02-11, 21:08
(2015-02-11, 20:20)zag Wrote: [ -> ]I'm getting a blank page when I click on a league, is that supposed to be happening?
Using Aeon nox 5
Nop it's supposed to navigate to league view /league plotview by default. Probably a bad installation.
I'll create a repo tonight to make this easier. Also I'm shipping a fanart per sport which makes the addon zip huge in size
2015-02-11, 21:31
of course, I will comment on my website
thanks
thanks
2015-02-12, 01:35
(2015-02-11, 21:08)enen92 Wrote: [ -> ](2015-02-11, 20:20)zag Wrote: [ -> ]I'm getting a blank page when I click on a league, is that supposed to be happening?
Using Aeon nox 5
Here is the repository I'll use until this is finished:
https://kodisportscenter.googlecode.com/...-1.0.0.zip
I'll push updates there often but not so often as github
Cheers
2015-02-12, 11:26
Hmm just tried a totally clean install and I still can't get past the football league screen.
I click on the Premier League badge, and it takes me to the programs >> add-ons kodi menu
