2015-01-24, 07:42
Hi there,
I made the mistake of installing kodi 14 using the XBMC PPAs under Mint 17.1. Doing a remove of kodi via apt-get I went and did a 'apt-get install xbmc' to go back to Gotham. However, the PPA configuration seems to have aliased XBMC to Kodi, so that it just reinstalls Kodi 14 instead of XBMC 13.2. I can see the packages are still there, but the way it's configured you can't install the old packages. Ie:
Package: xbmc
Source: kodi
Priority: extra
Section: oldlibs
Installed-Size: 192
Maintainer: wsnipex <wsnipex@xbmc.org>
Architecture: all
Version: 2:14.0~git20141223.1015-final-0trusty
Depends: kodi
Filename: pool/main/k/kodi/xbmc_14.0~git20141223.1015-final-0trusty_all.deb
MD5sum: 9861485afeda7157e7da29fa1c07b7a6
SHA1: cb0e2795e6d8689955754c8e526b12fdd66d9727
SHA256: eb87c9c60e73fd54d977d92eb75b5a49a6d891b1bfcf5a4aaf6c3eed51b6d9ed
Description: transitional dummy package
Description-md5: 1f317b04f78374dba7d1e14def0b7f80
Package: xbmc
Priority: optional
Section: video
Installed-Size: 46082
Maintainer: Debian XBMC Packaging Team <[email protected]>
Architecture: all
Version: 2:13.2~git20140817.2155-final-0trusty
Recommends: libvdpau1, libva-intel-vaapi-driver, libva1
Replaces: xbmc-data, xbmc-skin-confluence, xbmc-standalone
Suggests: xbmc-test-helper, xbmc-pvr-mythtv-cmyth, xbmc-pvr-vuplus, xbmc-pvr-vdr-vnsi, xbmc-pvr-njoy, xbmc-pvr-nextpvr, xbmc-pvr-mediaportal-tvserver, xbmc-pvr-tvheadend-hts, xbmc-pvr-dvbviewer, xbmc-pvr-argustv, xbmc-pvr-iptvsimple
Provides: xbmc-data, xbmc-skin-confluence, xbmc-standalone
Depends: xbmc-bin (>= 2:13.2~git20140817.2155-final-0trusty), xbmc-bin (<< 2:13.2~git20140817.2155-final-0trusty.1~), curl, mesa-utils, x11-utils, ttf-liberation | fonts-liberation, ttf-dejavu-core, python-bluez | python-lightblue, python-imaging, python-simplejson, libmad0, libass4, libssh-4 | libssh2-1, libnfs1, libbluray1, libshairport1, libshairplay0, libmp3lame0, libvorbisfile3, libaacs0, libflac8, libcec2 (>= 2.1.1), librtmp0, libgnutls26 | libgnutls28, libxslt1.1, python, python-support (>= 0.90.0)
Breaks: xbmc-data (<< 2:11.0~git20111222.22ad8e4), xbmc-skin-confluence (<< 2:11.0~git20111222.22ad8e4), xbmc-standalone (<< 2:11.0~git20111222.22ad8e4)
Filename: pool/main/x/xbmc/xbmc_13.2~git20140817.2155-final-0trusty_all.deb
MD5sum: 32eb1599d262133f411d86ab5e741cf1
SHA1: ca7acc7859cf10abfe249002474db3f314c42595
SHA256: b40d230f7fdea2710543effe9a31edbc99ae8de7d33ccb9904ffe122715922f6
Description: XBMC Media Center (arch-independent data package)
Description-md5: c715fd445ede63df73abecfe012c5dc2
I think I might be able to revert using the command: 'apt-get install xbmc:2:13.2~git20140817.2155-final-0trusty'
But I think it might be helpful to not alias xbmc to kodi for the sake of those of us who are still using an older version of Kodi/XBMC. Would this be possible?
Thanks - Matt.
Package: xbmc
Source: kodi
Priority: extra
Section: oldlibs
Installed-Size: 192
Architecture: all
Depends: kodi
Package: xbmc
Priority: optional
Section: video
Architecture: all
Thanks - Matt.
