Full Version: [OpenELEC 5.0] Kodi freezes while playing video files.
Hey. I have a problem with some files when using Kodi.
I built a HTPC with OpenELEC 5.0. Whenever I try to play some files, after a while the whole system freezes while playing a videofile. I first thought that maybe my CPU overheats, but it is at usually at about 40-50°C. Also the CPU is at about 10% when playing files.
Here is the log:
http://pastebin.com/9tg7m05M
I hope I did everything right, because I was not sure, since it is freezing.
Thanks for any suggestions what might be the error.
Quote:13:56:01 T:140296901121920 NOTICE: Host CPU: Intel® Pentium® CPU G3420 @ 3.20GHz, 2 cores available
-> https://bugs.freedesktop.org/show_bug.cgi?id=87564 kernel bug, no workaround known.
So right now there is nothing to do besides waiting?
Or should I change the CPU?
Thanks for the answer~
