Full Version: Restore issue
hi guys,
I have a backup from my 13.2 version of xbmc and I want to restore it to my new kodi version 14,
when I try to use the backup app to restore I got the message that the backup is from deferent version,
as there any option to use this restore or do in need to manual add all the stuff ?
thanks
also one moreSmile
I notice that the PVR add-on argus is gone ??
I cant find it in the add-on section
anyone pleaseSmile
Dont bump your thread within 24 hours. Just wait a bit.
Some addons arent compitable anymore with kodi helix. So yes...if you cant find the addon, then its hidden because incompatibility. There is an option in your side menu to show incompatible addons.
The database file has changed, too. For gotham it was 'MyMovies78' now its 'MyMovies90'. So how did you do your backup? Nor ally you should have done a copy of your userdatafolder and the move it to your new installation...done.
