2015-01-24, 22:00
Hello,
i am trying to install KodiBuntu from a bootable usb pen drive to the hdd of my htpc with the following options in the menu "Installation type":
[x] Erase disk and install Ubuntu
[x] Encrypt the new Ubuntu installation for security
[x] Use LVM with the new Ubuntu installation
...and unfortunately the following error is popping up at the end of the installation process:
"Unable to install GRUB in /dev/sda
Executing 'grub-install /dev/sda' failed
This is a fatal error."
when i switch to text mode and execute "sudo grub-install /dev/sda" i receive the error "grub-install: error: failed to get canonical path of 'aufs'".
i get this error with kodibuntu-14.0~helix_amd64.iso and kodibuntu-14.0rc~helix_i386.iso as well.
live mode is working for both iso images and the installation is also working like a charm when i uncheck the encrypt option, but that's not what i want.
is the encryption option broken in KodiBuntu?
can anybody tell me a workaround?
any help would be appreciated.
thank you,
andized
thank you,
andized
