2006-08-19, 08:18
mobileXBMC 2.0
by Sindre Sorhus
Download it here!
mobileXBMC is a very fast and simple webcontrol to XBMC, and with a lot of features. You can use it on a PDA, Computer and Cellphone (but with Opera Mini on the cellphone (sorry guys, it just couln't find a way to select music, pictures and videos without the ASP script, and I also had to use frameset)). You can use whatever connection you want as long as you can connect to the web withit (wlan, gprs, 3g, umts, or whatever...).
Demo
Try the demo here
You can only look at it, because it have to be on a Xbox to work.
Screenshots
Current functions
- Too many too write here, just try it out for yourself or test it in his demo.
Known bugs
- The left and right trigger remote doesn't work, therefor it isn't added.
- I had to use frameset to remove the OK message from XBMC, somebody got another solution? mail me.
- Both the ASP and the frameset make it impossible to run mobileXBMC on a wap cellphone.
Installation
Extract the .zip file, and drag the "web" folder into the XBMC folder on your XBOX.
Remember to enable webserver in your XBMC settings.
Configuration
You can add and edit the "Launch apps/scripts" meny, by opening "appsmain.html" in f.eks notepad, and
either edit one of the links that already is there, or copy one of them and then change it.
Use it
When you're ready, try it by going to http://IP:Port/
Use the port you chosed in the XBMC webserver settings.
Example: http://193.215.150.121:200/
You can find your IP by visiting this page: http://www.whatismyip.com
If you have a router remember to open/route the port of your xbmc webserver
If you have any comments, questions, bugs, ideas, or something, contact me on:
[email protected] with XBMC in the subject.
by Sindre Sorhus
Download it here!
Demo
Try the demo here
Screenshots
Current functions
Known bugs
Installation
Configuration
Use it
