2006-08-19, 15:31
Hi!
I have searched all Internet (I think) for an answer and I have tried all possible and impossible things to get my wireless network to connect to the Xbox.
Now it's no problem to reach the ftp in the EVO dashboard but as soon as I open XBMC and tries to connect to and from it nothing works. If I connect a wired cable everything works perfect! I have edited the user file to connect to the computer that will stream ans as it works perfectly with the wired cable it's correct...
I use:
XBMC v.
Windows XP SP2 (two computers)
Netgear WGE111 (wireless gaming adaptor)
Netgear WGT624v3 (router)
Ip settings as follows:
Router: 192.168.0.1
XP: 192.168.0.6
Gaming adaptor: 192.168.0.5
Laptop: DHCP
XBMC: have tried both DHCP and 192.168.0.7
All units uses 255.255.255.0 as subnet mask.
Firewalls are off and security in the router has been both off and on.
As it works with ftp in the dashboard I don't see why it won't work with streaming in XBMC!?
Is there any ports I should open for XBMC in the router? I can't open all ports (at least I can't find such an option) in the router. Is there any specific ports XBMC uses to connect and/or stream?
Please, pretty please, help me! I'm going insane!!!
I use:
XBMC v.
Router: 192.168.0.1
XP: 192.168.0.6
Laptop: DHCP
