2015-01-26, 13:41
Hi.
In my TMM library, have multilpe sources like NAS and USB External disks.
When open TMM with some USB external disks offline TMM takes a long time (10' 44'') to start while display splash screen.
In my collection there are 531 movies and 143 are in the offline usb disk.
When TMM start, if I select a movie that is on the offline disk or apply any filter with movies that are on the offline disk, takes a long time too.
Regards
2015-01-26 12:19:10,673 INFO [main] org.tinymediamanager.TinyMediaManager:120 - =====================================================
2015-01-26 12:19:10,688 INFO [main] org.tinymediamanager.TinyMediaManager:121 - === tinyMediaManager (c) 2012-2014 Manuel Laggner ===
2015-01-26 12:19:10,688 INFO [main] org.tinymediamanager.TinyMediaManager:122 - =====================================================
2015-01-26 12:19:10,688 INFO [main] org.tinymediamanager.TinyMediaManager:123 - tmm.version : 2.6.5 (r1840)
2015-01-26 12:19:11,094 INFO [main] org.tinymediamanager.TinyMediaManager:126 - tmm.supporter : THANKS FOR DONATING - ALL FEATURES UNLOCKED :)
2015-01-26 12:19:11,094 INFO [main] org.tinymediamanager.TinyMediaManager:129 - os.name : Windows 8.1
2015-01-26 12:19:11,094 INFO [main] org.tinymediamanager.TinyMediaManager:130 - os.version : 6.3
2015-01-26 12:19:11,094 INFO [main] org.tinymediamanager.TinyMediaManager:131 - os.arch : x86
2015-01-26 12:19:11,094 INFO [main] org.tinymediamanager.TinyMediaManager:133 - java.version : 1.8.0_31
2015-01-26 12:19:11,110 INFO [main] org.tinymediamanager.TinyMediaManager:147 - java.swt : false
2015-01-26 12:19:11,110 INFO [main] org.tinymediamanager.TinyMediaManager:635 - default encoding : UTF-8 | UTF8 | UTF-8
2015-01-26 12:19:11,110 INFO [main] org.tinymediamanager.TinyMediaManager:635 - set encoding to : UTF-8 | UTF8 | UTF-8
2015-01-26 12:19:11,126 INFO [main] org.tinymediamanager.TinyMediaManager:170 - System language : es_ES
2015-01-26 12:19:11,126 INFO [main] org.tinymediamanager.TinyMediaManager:171 - GUI language : en_US
2015-01-26 12:19:11,126 INFO [main] org.tinymediamanager.TinyMediaManager:172 - Scraper language : EspaƱol
2015-01-26 12:19:11,126 INFO [main] org.tinymediamanager.TinyMediaManager:173 - TV Scraper lang : English
2015-01-26 12:19:11,235 INFO [main] org.tinymediamanager.TinyMediaManager:221 - =====================================================
2015-01-26 12:19:11,266 DEBUG [main] org.tinymediamanager.TinyMediaManager:420 - Startup (0%) starting tinyMediaManager
2015-01-26 12:19:11,266 INFO [main] org.tinymediamanager.TinyMediaManager:226 - starting tinyMediaManager
2015-01-26 12:19:11,266 DEBUG [main] org.tinymediamanager.TinyMediaManager:420 - Startup (20%) loading MediaInfo libs
2015-01-26 12:19:11,282 DEBUG [main] org.tinymediamanager.TinyMediaManager:265 - Loading native mediainfo lib from: native/windows-x86
2015-01-26 12:19:11,782 INFO [main] org.tinymediamanager.TinyMediaManager:269 - Using MediaInfoLib - v0.7.69
2015-01-26 12:19:11,798 DEBUG [main] org.tinymediamanager.TinyMediaManager:420 - Startup (30%) loading movie module
2015-01-26 12:19:12,313 INFO [main] o.tinymediamanager.core.movie.MovieList:331 - found 531 movies in database
2015-01-26 12:19:12,704 INFO [main] o.tinymediamanager.core.movie.MovieList:374 - found 112 movieSets in database
2015-01-26 12:19:12,735 DEBUG [main] org.tinymediamanager.TinyMediaManager:420 - Startup (40%) loading TV show module
2015-01-26 12:19:12,735 INFO [main] o.t.core.tvshow.TvShowList:261 - found 0 tv shows in database
2015-01-26 12:19:12,735 DEBUG [main] org.tinymediamanager.TinyMediaManager:420 - Startup (70%) cleaning cache
2015-01-26 12:19:12,970 DEBUG [main] org.tinymediamanager.TinyMediaManager:420 - Startup (80%) loading ui
2015-01-26 12:19:13,079 DEBUG [main] o.tinymediamanager.ui.movies.MoviePanel:242 - loading MovieList
2015-01-26 12:29:51,758 DEBUG [main] org.tinymediamanager.TinyMediaManager:420 - Startup (100%) finished starting :)
2015-01-26 12:29:51,883 DEBUG [trackEventThread] org.tinymediamanager.scraper.util.Url:223 - getting http://www.google-analytics.com/collect?v=1&tid=UA-35564534-5&cid=ead30075-5cea-41b1-9efd-5f3283df6ddb&an=tinyMediaManager&av=1840&t=event&ec=startup&ea=startup&aip=1&je=1&ul=es-ES&vp=1550x1040&sr=1280x1024&cd1=Windows+8.1&cd2=x86&cd3=1.8&cd4=2.6.5&cd5=1&z=1422271791758
2015-01-26 12:29:56,773 INFO [updateThread] org.tinymediamanager.core.UpdaterTask:56 - Checking for updates...
2015-01-26 12:29:56,773 DEBUG [updateThread] org.tinymediamanager.scraper.util.Url:223 - getting http://tinymediamanager.googlecode.com/svn/dist/digest.txt
2015-01-26 12:29:56,961 INFO [updateThread] org.tinymediamanager.core.UpdaterTask:89 - Already up2date :)
2015-01-26 12:29:57,007 DEBUG [main] org.tinymediamanager.ui.MainWindow:308 - update result was: false
Regards
