So here is the log file. Just starting up, entering movies, see movie details and start the movie.. after few seconds i quit Kodi.
19:58:15 T:6704 NOTICE: special://profile/ is mapped to: special://masterprofile/
19:58:15 T:6704 NOTICE: -----------------------------------------------------------------------
19:58:15 T:6704 NOTICE: Starting xxx (14.2-RC1 Git:20150311-e7ba06f). Platform: Windows NT x86 32-bit
19:58:15 T:6704 NOTICE: Using Release xxx x32 build
19:58:15 T:6704 NOTICE: xxx compiled Mar 11 2015 by MSVC 180030723 for Windows NT x86 32-bit version 6.0 (0x06000000)
19:58:15 T:6704 NOTICE: Running on Gigabyte Technology Co., Ltd. device with Windows 7 SP1, kernel: Windows NT x86 64-bit version 6.1
19:58:15 T:6704 NOTICE: Host CPU: Intel® Core i7-3770K CPU @ 3.50GHz, 8 cores available
19:58:15 T:6704 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
19:58:15 T:6704 NOTICE: Running with administrator rights
19:58:15 T:6704 NOTICE: Aero is enabled
19:58:15 T:6704 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\xxx
19:58:15 T:6704 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\xxx
19:58:15 T:6704 NOTICE: special://masterprofile/ is mapped to: C:\Users\desktop\AppData\Roaming\xxx\userdata
19:58:15 T:6704 NOTICE: special://home/ is mapped to: C:\Users\desktop\AppData\Roaming\xxx\
19:58:15 T:6704 NOTICE: special://temp/ is mapped to: C:\Users\desktop\AppData\Roaming\xxx\cache
19:58:15 T:6704 NOTICE: The executable running is: C:\Program Files (x86)\xxx\xxx.exe
19:58:15 T:6704 NOTICE: Local hostname: desktop-PC
19:58:15 T:6704 NOTICE: Log File is located: C:\Users\desktop\AppData\Roaming\xxx\xxx.log
19:58:15 T:6704 NOTICE: load settings...
19:58:15 T:6704 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
19:58:15 T:6704 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
19:58:15 T:6704 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
19:58:15 T:6704 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
19:58:15 T:6704 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>xxx.xxx.xxx.xxx</host>
<port>3306</port>
<user>xxx</user>
<pass>xxx</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>xxx</user>
<pass>xxx</pass>
</musicdatabase>
<videolibrary>
<importwatchedstate>true</importwatchedstate>
</videolibrary>
</advancedsettings>
19:58:15 T:6704 WARNING: VIDEO database configuration is experimental.
19:58:15 T:6704 NOTICE: Default DVD Player: dvdplayer
19:58:15 T:6704 NOTICE: Default Video Player: dvdplayer
19:58:15 T:6704 NOTICE: Default Audio Player: paplayer
19:58:15 T:6704 NOTICE: Disabled debug logging due to GUI setting. Level 0.
19:58:15 T:6704 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
19:58:15 T:6704 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
19:58:15 T:6704 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
19:58:15 T:6704 NOTICE: Loaded playercorefactory configuration
19:58:15 T:6704 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
19:58:15 T:6704 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
19:58:15 T:5628 NOTICE: Thread ActiveAE start, auto delete: false
19:58:15 T:1900 NOTICE: Thread AESink start, auto delete: false
19:58:15 T:5628 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTSHD" on device "AMD HDMI Output (AMD High Definition Audio Device)" seems to be not supported.
19:58:15 T:5628 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_TRUEHD" on device "AMD HDMI Output (AMD High Definition Audio Device)" seems to be not supported.
19:58:15 T:5628 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_EAC3" on device "AMD HDMI Output (AMD High Definition Audio Device)" seems to be not supported.
19:58:15 T:5628 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTS" on device "AMD HDMI Output (AMD High Definition Audio Device)" seems to be not supported.
19:58:15 T:5628 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_AC3" on device "AMD HDMI Output (AMD High Definition Audio Device)" seems to be not supported.
19:58:15 T:5628 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_AAC" on device "AMD HDMI Output (AMD High Definition Audio Device)" seems to be not supported.
19:58:15 T:5628 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: sample rate 192khz on device "AMD HDMI Output (AMD High Definition Audio Device)" seems to be not supported.
19:58:15 T:5628 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_LPCM" on device "AMD HDMI Output (AMD High Definition Audio Device)" seems to be not supported.
19:58:15 T:5628 NOTICE: Found 2 Lists of Devices
19:58:15 T:5628 NOTICE: Enumerated DIRECTSOUND devices:
19:58:15 T:5628 NOTICE: Device 1
19:58:15 T:5628 NOTICE: m_deviceName : {ABC93177-98FF-420F-B9A5-9DDA076A8C05}
19:58:15 T:5628 NOTICE: m_displayName : HDMI - AMD HDMI Output (AMD High Definition Audio Device)
19:58:15 T:5628 NOTICE: m_displayNameExtra: DIRECTSOUND: AMD HDMI Output (AMD High Definition Audio Device)
19:58:15 T:5628 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
19:58:15 T:5628 NOTICE: m_channels : FL,FR
19:58:15 T:5628 NOTICE: m_sampleRates : 48000
19:58:15 T:5628 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3,AE_FMT_DTS
19:58:15 T:5628 NOTICE: Device 2
19:58:15 T:5628 NOTICE: m_deviceName : default
19:58:15 T:5628 NOTICE: m_displayName : default
19:58:15 T:5628 NOTICE: Enumerated WASAPI devices:
19:58:15 T:5628 NOTICE: m_displayNameExtra: WASAPI: AMD HDMI Output (AMD High Definition Audio Device)
19:58:15 T:5628 NOTICE: m_sampleRates : 192000,48000,44100,32000
19:58:15 T:5628 NOTICE: m_dataFormats : AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
19:58:15 T:6704 NOTICE: Running database version Addons16
19:58:15 T:6704 NOTICE: ADDONS: Using repository repository.xbmc.org
19:58:15 T:4020 NOTICE: Thread RemoteControl start, auto delete: false
19:58:15 T:944 NOTICE: Thread PeripBusCEC start, auto delete: false
19:58:15 T:5708 NOTICE: Thread PeripBusUSB start, auto delete: false
19:58:15 T:6704 NOTICE: Found screen: Generic PnP Monitor on ATI Radeon HD 4800 Series, adapter 0.
19:58:15 T:6704 NOTICE: Primary mode: 1920x1080@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 640x480@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Previous line repeats 2 times.
19:58:15 T:6704 NOTICE: Additional mode: 640x480@ 59.94 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 640x480@ 73.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 640x480@ 75.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 720x480@ 29.97i - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 720x480@ 30.00i - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 720x480@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 720x480@ 59.94 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 720x480@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 720x576@ 25.00i - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 720x576@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 800x600@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 800x600@ 56.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 800x600@ 72.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 800x600@ 75.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 848x480@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 848x480@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1024x768@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1024x768@ 70.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1024x768@ 75.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1152x648@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1152x648@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1152x864@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1152x864@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1152x864@ 75.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1280x720@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1280x720@ 59.94 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1280x768@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1280x800@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1280x800@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1280x960@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1280x960@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1280x1024@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1280x1024@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1280x1024@ 75.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1360x768@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1360x768@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1360x1024@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1360x1024@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1366x768@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1366x768@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1400x1050@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1400x1050@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1440x900@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1440x900@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1440x900@ 75.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1600x900@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1600x900@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1600x1200@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1680x1050@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1680x1050@ 59.94 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1680x1050@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1776x1000@ 25.00i - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1776x1000@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1776x1000@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1920x1080@ 25.00i - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1920x1080@ 29.97i - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1920x1080@ 30.00i - Full Screen
19:58:15 T:6704 NOTICE: Additional mode: 1920x1080@ 50.00 - Full Screen
19:58:15 T:6704 NOTICE: Checking resolution 16
19:58:16 T:6704 NOTICE: Running database version Addons16
19:58:16 T:6704 NOTICE: Running database version ViewModes6
19:58:16 T:6704 NOTICE: Running database version Textures13
19:58:21 T:6704 NOTICE: Running database version MyMusic48
19:58:26 T:6704 NOTICE: Running database version MyVideos90
19:58:26 T:6704 NOTICE: Running database version TV26
19:58:26 T:6704 NOTICE: Running database version Epg8
19:58:26 T:6704 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
19:58:26 T:6704 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
19:58:26 T:6704 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
19:58:26 T:6704 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
19:58:26 T:5556 NOTICE: Thread LanguageInvoker start, auto delete: false
19:58:26 T:6704 NOTICE: CApplication::UpdateLibraries: Starting video library startup scan
19:58:26 T:5556 NOTICE: -->Python Interpreter Initialized<--
19:58:32 T:6704 NOTICE: initialize done
19:58:32 T:3632 NOTICE: Thread VideoInfoScanner start, auto delete: false
19:58:32 T:6704 NOTICE: Running the application...
19:58:42 T:4624 NOTICE: Thread JobWorker start, auto delete: true
19:59:07 T:6704 NOTICE: starting zeroconf publishing
19:59:07 T:1592 NOTICE: Thread JobWorker start, auto delete: true
19:59:07 T:6704 NOTICE: Webserver: Starting...
19:59:07 T:6704 ERROR: WebServer: Failed to start the webserver
19:59:07 T:6704 NOTICE: starting upnp renderer
19:59:07 T:6704 NOTICE: Platinum [platinum.core.upnp]: Starting UPnP...
19:59:07 T:6704 NOTICE: Platinum [platinum.core.upnp]: Starting Device...
19:59:07 T:6704 NOTICE: Platinum [platinum.core.http.server]: HttpServer listening on 0.0.0.0:1416
19:59:07 T:6704 NOTICE: ES: Starting event server
19:59:07 T:6680 NOTICE: Thread TCPServer start, auto delete: false
19:59:07 T:3232 NOTICE: Thread EventServer start, auto delete: false
19:59:07 T:3232 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
19:59:07 T:6840 NOTICE: Thread AirPlayServer start, auto delete: false
19:59:07 T:4896 NOTICE: Thread JobWorker start, auto delete: true
19:59:07 T:3232 NOTICE: UDP: Listening on port 9777
19:59:17 T:3632 NOTICE: VideoInfoScanner: Starting scan ..
19:59:18 T:3632 WARNING: No information found for item 'smb://xxx.xxx.xxx.xxx/Movies/911 - Loose Change 2nd Edition/911 - Loose Change 2nd Edition DVDRip (ConCen) XviD.avi', it won't be added to the library.
19:59:18 T:3632 WARNING: No information found for item 'smb://xxx.xxx.xxx.xxx/Movies/911 - Loose Change 2nd Edition/911 - Loose Change 2nd Edition Extra Footage DVDRip (ConCen) XviD.avi', it won't be added to the library.
19:59:20 T:3632 WARNING: No information found for item 'smb://xxx.xxx.xxx.xxx/Movies/Bud Spencer & Terence Hill/A.genious.two.partners.and.a.dupe.DVD.XviD/A.genious.two.partners.and.a.dupe.DVD.XviD.avi', it won't be added to the library.
19:59:21 T:3632 WARNING: No information found for item 'smb://xxx.xxx.xxx.xxx/Movies/Bud Spencer & Terence Hill/Im.for.the.hipotamus.DVD.XviD/Im.for.the.hipotamus.DVD.XviD.avi', it won't be added to the library.
19:59:21 T:3632 WARNING: No information found for item 'smb://xxx.xxx.xxx.xxx/Movies/Cat Run (2011)/noscreen-cat.run-720p.mkv', it won't be added to the library.
19:59:24 T:4444 NOTICE: Thread JobWorker start, auto delete: true
19:59:24 T:3632 WARNING: No information found for item 'stack://smb://xxx.xxx.xxx.xxx/Movies/Invictus/CD1/xscr-invictus_part1[dupedb.com].avi , smb://xxx.xxx.xxx.xxx/Movies/Invictus/CD2/xscr-invictus_part2[dupedb.com].avi', it won't be added to the library.
19:59:26 T:3632 WARNING: No information found for item 'stack://smb://xxx.xxx.xxx.xxx/Movies/Whats love got to do with it/Whats.Love.Got.To.Do.With.It.SWESUB.DVDRip.XviD-bullshit.CD01.avi , smb://xxx.xxx.xxx.xxx/Movies/Whats love got to do with it/Whats.Love.Got.To.Do.With.It.SWESUB.DVDRip.XviD-bullshit.CD02.avi', it won't be added to the library.
19:59:26 T:3632 WARNING: No information found for item 'smb://xxx.xxx.xxx.xxx/Movies/Zack and Miri make a Porn Movie/bald-zac.avi', it won't be added to the library.
19:59:26 T:3632 WARNING: VIDEO::CVideoInfoScanner:
rocess directory 'smb://xxx.xxx.xxx.xxx/Movies/A Dangerous Method 2011 720p BRRip x264 AAC-26K/' does not exist - skipping scan.
rocess directory 'smb://xxx.xxx.xxx.xxx/Movies/Cat.Run.2011.720p.BluRay.x264-NOSCREENS/' does not exist - skipping scan.
rocess directory 'smb://xxx.xxx.xxx.xxx/TV Shows/ Revenge/' does not exist - skipping scan.
19:59:33 T:3632 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:25
20:00:12 T:6200 NOTICE: Thread JobWorker start, auto delete: true
20:00:40 T:4908 NOTICE: Previous line repeats 2 times.
20:00:40 T:4908 NOTICE: Thread BackgroundLoader start, auto delete: false
20:00:53 T:4624 ERROR: CDVDDemuxFFmpeg::Open - Error, could not open file smb://xxx.xxx.xxx.xxx/Movies/The Cabin in the Woods.mkv
20:00:53 T:4624 ERROR: CDVDDemuxFFmpeg::Open - Error, could not open file smb://xxx.xxx.xxx.xxx/Movies/The Longshots (2008).avi
20:00:54 T:6200 ERROR: CDVDDemuxFFmpeg::Open - error probing input format, smb://xxx.xxx.xxx.xxx/Movies/The Spirit.wmv
20:00:54 T:6708 ERROR: CDVDDemuxFFmpeg::Open - Error, could not open file smb://xxx.xxx.xxx.xxx/Movies/Lucky you/._Luck you cd1.avi
20:00:54 T:4624 ERROR: CDVDDemuxFFmpeg::Open - Error, could not open file smb://xxx.xxx.xxx.xxx/Movies/Lucky you/._Lucky you cd2.avi
20:00:55 T:7112 NOTICE: Thread BackgroundLoader start, auto delete: false
20:01:01 T:6200 ERROR: CDVDDemuxFFmpeg::Open - Error, could not open file smb://xxx.xxx.xxx.xxx/Movies/The Cabin in the Woods.mkv
20:01:02 T:4624 ERROR: CDVDDemuxFFmpeg::Open - Error, could not open file smb://xxx.xxx.xxx.xxx/Movies/The Longshots (2008).avi
20:01:02 T:5836 ERROR: CDVDDemuxFFmpeg::Open - Error, could not open file smb://xxx.xxx.xxx.xxx/Movies/Lucky you/._Lucky you cd2.avi
20:01:02 T:6200 ERROR: CDVDDemuxFFmpeg::Open - Error, could not open file smb://xxx.xxx.xxx.xxx/Movies/Lucky you/._Luck you cd1.avi
20:01:02 T:4624 ERROR: CDVDDemuxFFmpeg::Open - error probing input format, smb://xxx.xxx.xxx.xxx/Movies/The Spirit.wmv
20:02:05 T:6704 NOTICE: DVDPlayer: Opening: smb://xxx.xxx.xxx.xxx/Movies/'71.2014.720p.HDRiP.X264.AAC.2.0-Blackjesus/'71.2014.720p.HDRiP.X264.AAC.2.0-Blackjesus.mkv
20:02:05 T:6704 WARNING: CDVDMessageQueue(player):
ut MSGQ_NOT_INITIALIZED
20:02:05 T:6704 NOTICE: DXVA::CProcessorHD:
reInit - The Direct3d device doesn't support DXVA-HD.
20:02:05 T:6704 NOTICE: CWinRenderer:
reinit - could not init DXVA-HD processor - skipping
20:02:05 T:2708 NOTICE: Thread DVDPlayer start, auto delete: false
20:02:05 T:2708 NOTICE: Creating InputStream
20:02:05 T:2708 NOTICE: Creating Demuxer
20:02:05 T:2708 NOTICE: Opening stream: 0 source: 256
20:02:05 T:2708 NOTICE: Creating video codec with codec id: 28
20:02:05 T:2708 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
20:02:05 T:2708 NOTICE: Creating video thread
20:02:05 T:2708 NOTICE: Opening stream: 1 source: 256
20:02:05 T:1096 NOTICE: Thread DVDPlayerVideo start, auto delete: false
20:02:05 T:1096 NOTICE: running thread: video_thread
20:02:05 T:2708 NOTICE: Finding audio codec for: 86018
20:02:05 T:2708 NOTICE: Creating audio thread
20:02:05 T:6892 NOTICE: Thread DVDPlayerAudio start, auto delete: false
20:02:05 T:1096 NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x538)
20:02:05 T:6892 NOTICE: running thread: CDVDPlayerAudio:
rocess()
20:02:05 T:1096 NOTICE: DXVA::CDXVAContext::CreateDecoder - hw may not support multiple decoders, releasing existing ones
20:02:05 T:6892 NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 96000, no pass-through)
20:02:05 T:1096 NOTICE: DXVA::CDecoder::Close - closing decoder
20:02:05 T:1096 NOTICE: fps: 25.000000, pwidth: 1280, pheight: 538, dwidth: 1280, dheight: 538
20:02:05 T:1096 NOTICE: Display resolution ADJUST : 1920x1080@ 50.00 - Full Screen (80) (weight: 0.000)
20:02:05 T:1096 NOTICE: D3D: rendering method forced to DXVA processor
20:02:25 T:6704 WARNING: Platinum [platinum.core.statevariable]: Invalid value of 0 for state variable TransportPlaySpeed
20:02:25 T:6704 WARNING: Platinum [platinum.core.statevariable]: Allowed: 1
20:02:26 T:6704 WARNING: CWinRenderer::UpdateVideoFilter - chosen scaling method 1 is not supported by renderer
20:02:37 T:6704 WARNING: Platinum [platinum.core.statevariable]: Invalid value of 0 for state variable TransportPlaySpeed
20:02:37 T:6704 WARNING: Platinum [platinum.core.statevariable]: Allowed: 1
20:02:38 T:6704 NOTICE: CDVDPlayer::CloseFile()
20:02:38 T:6704 NOTICE: DVDPlayer: waiting for threads to exit
20:02:38 T:2708 NOTICE: CDVDPlayer::OnExit()
20:02:38 T:2708 NOTICE: Closing stream player 1
20:02:38 T:2708 NOTICE: Waiting for audio thread to exit
20:02:38 T:6892 NOTICE: thread end: CDVDPlayerAudio::OnExit()
20:02:38 T:2708 NOTICE: Closing audio device
20:02:38 T:2708 NOTICE: Deleting audio codec
20:02:38 T:2708 NOTICE: Closing stream player 2
20:02:38 T:2708 NOTICE: waiting for video thread to exit
20:02:38 T:1096 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
20:02:38 T:1096 NOTICE: thread end: video_thread
20:02:38 T:2708 NOTICE: deleting video codec
20:02:38 T:2708 NOTICE: DXVA::CDecoder::Close - closing decoder
20:02:38 T:2708 NOTICE: DXVA::Close - closing decoder context
20:02:38 T:6704 NOTICE: DVDPlayer: finished waiting
20:02:43 T:7076 NOTICE: Thread BackgroundLoader start, auto delete: false
20:02:50 T:5100 NOTICE: Thread JobWorker start, auto delete: true
20:02:59 T:4444 NOTICE: Thread BackgroundLoader start, auto delete: false
20:03:04 T:6704 NOTICE: CDVDPlayer::CloseFile()
20:03:04 T:6704 NOTICE: DVDPlayer: waiting for threads to exit
20:03:04 T:6704 NOTICE: DVDPlayer: finished waiting
20:03:04 T:5136 NOTICE: Thread JobWorker start, auto delete: true
20:03:09 T:6704 NOTICE: Storing total System Uptime
20:03:09 T:6704 NOTICE: Saving settings
20:03:09 T:6704 NOTICE: stop all
20:03:42 T:6704 NOTICE: stop player
20:03:42 T:6704 NOTICE: ES: Stopping event server
20:03:43 T:6704 NOTICE: stopping upnp
20:03:43 T:6704 NOTICE: Platinum [platinum.core.upnp]: Stopping UPnP...
20:03:43 T:5104 WARNING: Platinum [platinum.core.http.servertask]: PLT_HttpListenTask exiting with -20021 (NPT_ERROR_CANCELLED)
20:03:43 T:6704 WARNING: Platinum [platinum.core.http.server]: NPT_CHECK failed, result=-20009 (NPT_ERROR_INVALID_STATE) [(((-20000-0) - 9))]
20:03:43 T:3612 WARNING: Platinum [neptune.bufferedstreams]: NPT_CHECK failed, result=-20021 (NPT_ERROR_CANCELLED) [(__result)]
20:03:43 T:3612 WARNING: Platinum [platinum.core.http.servertask]: NPT_CHECK failed, result=-20021 (NPT_ERROR_CANCELLED) [(res)]
20:03:43 T:6704 WARNING: Platinum [platinum.core.upnp]: NPT_CHECK failed, result=-20009 (NPT_ERROR_INVALID_STATE) [(((-20000-0) - 9))]
20:03:43 T:6704 NOTICE: stopping zeroconf publishing
20:03:43 T:3232 NOTICE: ES: UDP Event server stopped
20:03:43 T:6704 NOTICE: stop sap announcement listener
20:03:43 T:6704 NOTICE: clean cached files!
20:03:43 T:6704 NOTICE: unload skin
20:03:43 T:6704 NOTICE: stopped
20:03:43 T:6704 NOTICE: destroy
20:03:43 T:6704 NOTICE: closing down remote control service
20:03:43 T:6704 NOTICE: unload sections
20:03:43 T:6704 NOTICE: special://profile/ is mapped to: special://masterprofile/
20:03:43 T:6704 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
20:03:43 T:6704 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
20:03:43 T:6704 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
20:03:43 T:6704 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
20:03:43 T:6704 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
20:03:43 T:6704 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
20:03:43 T:6704 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
20:03:43 T:6704 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
20:03:43 T:6704 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
20:03:43 T:6704 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
20:03:43 T:6704 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
20:03:43 T:6704 NOTICE: application stopped...
20:03:43 T:6704 ERROR: dllFreeLibrary - Invalid hModule specified
