Full Version: Custom background images (themes)
Another question...sorry I uninstalled & reinstalled XBMC recently (Still haven't updated to Kodi which apparently it is now)
I saved a "my themes" folder I had with all custom images I used to use as backgrounds for movies, settings, music, shutdown, etc..but I can't remember where I was supposed to put that folder or how I'm supposed to set it up that way again
It depends on what skin you are using. For example, I use Aeon Shednox Helix (Aeon Nox 4 based) and it allows you to specify the path, so you can save them anywhere you want.
