2015-01-28, 22:43
kudos to all you brainiacs on here. I though I could pull it off but it is very hard and way too many settings. All the guides I have found online seem to be a bit different from what I have.
I had been running win7 wmc using the hdhomerun dual tuner and it worked fine and recorded my shows with a guide. The macbook pro bootcamp that was running that croaked so Im trying to use kodi on a cubox.
I ABSOLUTLY LOVE KODI and the way it plays back local mo4 files and it would be great if I could just get it to timeshift/record live tv from my roof antenna through hdhomerun
cubox i4 pro
flashed openelec 5.0.0 form their support site
internet via ethernet only
enabled addon/pvr client/tvheadend htsp client 1.9.39 frontend
set ip to same ip as in system/system info
added and enabled hdhomerun add on
HDhomerun HDHR-3
updated firmware 20141124
cat-5 to hub
HDhomerun osx sees it fine
hdhomerun add-on 4.3.2. DVB driver
added and enabled both back end and front end and was able to get on back end through a web browser but it is not the same layout as what is show in the many online guides.
I did at one point get in to the backend via a web interface but can’t anymore.
Is there any good links that show hot to do this?
thanks
cubox i4 pro
HDhomerun HDHR-3
cat-5 to hub
thanks
