Full Version: PowerDVD as additional Player?
Hello,
I used the MCE with PowerDVD 13 before. Now I moved to Kodi and it worked fine. Sometime I have problem with some BDs and the internal player and in this case I want to use PowerDVD. Is there an option to add PDVD as an additional programm or something like that to Kodi? I only found tutorials to replace the build-in player with PowerDVD what is not the solutions I want. I want to play all contents with the built-in players but want also the possibility, to start PowerDVD directly from the Kodi GUI.
Maybe you can help me. Thanks and regards.
of course. add it to playercorefactory.xml, don't assign it by default. you then have it accessible from the context menu under play using.
Thanks. Some things are so easy. ;-) It works fine...
