Hello,
I was using kodi for a while on android with no problem. Then I tried a movie and it freezed.
I had to press the home button on android.
Now, kodi does not start at all, I get a black screen.
Tried clearing the cache and stopping the app, but there is no way to make it start again.
Any clues?
This is the log
07:32:39 T:1284464 NOTICE: special://profile/ is mapped to: special://masterprofile/
07:32:39 T:1284464 NOTICE: -----------------------------------------------------------------------
07:32:39 T:1284464 NOTICE: Starting Kodi (14.0 Git:2014-12-23-ad747d9-dirty). Platform: Android ARM 32-bit
07:32:39 T:1284464 NOTICE: Using Release Kodi x32 build
07:32:39 T:1284464 NOTICE: Kodi compiled Dec 23 2014 by GCC 4.8.0 for Android ARM 32-bit API level 14 (API level 14)
07:32:39 T:1284464 NOTICE: Running on MBX Android Smart TV Box with Android 4.0.3 API level 15, kernel: Linux ARM 32-bit version 2.6.34
07:32:39 T:1284464 NOTICE: FFmpeg version: 14.0rc3-Helix-79-gad747d9-xbmc-2.4.4-Helix
07:32:39 T:1284464 NOTICE: Host CPU: ARMv7 Processor rev 1 (v7l), 0 cores available
07:32:39 T:1284464 NOTICE: Product: c03ref, Device: c03ref, Board: c03ref - Manufacturer: MBX, Brand: MBX, Model: Android Smart TV Box, Hardware: amlogic
07:32:39 T:1284464 NOTICE: ARM Features: Neon enabled
07:32:39 T:1284464 NOTICE: special://xbmc/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
07:32:39 T:1284464 NOTICE: special://xbmcbin/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
07:32:39 T:1284464 NOTICE: special://masterprofile/ is mapped to: /mnt/sdcard/Android/data/org.xbmc.kodi/files/.kodi/userdata
07:32:39 T:1284464 NOTICE: special://home/ is mapped to: /mnt/sdcard/Android/data/org.xbmc.kodi/files/.kodi
07:32:39 T:1284464 NOTICE: special://temp/ is mapped to: /mnt/sdcard/Android/data/org.xbmc.kodi/files/.kodi/temp
07:32:39 T:1284464 NOTICE: The executable running is:
07:32:39 T:1284464 NOTICE: Local hostname: localhost
07:32:39 T:1284464 NOTICE: Log File is located: /mnt/sdcard/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
07:32:40 T:1284464 NOTICE: load settings...
07:32:40 T:1284464 DEBUG: static int CAndroidFeatures::GetVersion(): android.os.Build.VERSION 15
07:32:40 T:1284464 NOTICE: aml_present, rtn(13)
07:32:40 T:1284464 ERROR: CSettings: error loading settings definition from special://xbmc/system/settings/settings.xml, Line 0
Failed to open file
07:32:40 T:1284464 FATAL: Unable to load settings definitions
Your install is very broken and Kodi seems to be missing very important files. I would suggest reinstalling it.
What is broken?
And what files are missing?
It is not the first time that it happens to me. I had to reinstall many times.
I would like to know why it happens...
when I've downloaded Kodi Helix and after the inital installation mine doesn't seem to work at all. But gotham works fine. its really weird.
(2015-01-31, 11:39)Ned Scott Wrote: [ -> ]Your install is very broken and Kodi seems to be missing very important files. I would suggest reinstalling it.
Could you please tell me what is broken and what files are missing?
It tells you in the log file:
Failed to open file
The internal settings.xml file is corrupted or missing or something. I honestly have no idea why this would happen so often to you.
OK I got that thanks.
I did a fresh install, kodi is now working.
But where should that settings.xml file be located?
I go to /sdcard/Android/data/org.xbmc.kodi/files/.kodi/system
And it is empty.
Where is the settings.xml in Android?
"special://xbmc/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets"
"special://xbmc/system/settings/settings.xml" = "/data/data/org.xbmc.kodi/cache/apk/assets/system/settings/settings.xml"
Because it is installed the first time Kodi is run (in cache), does never change and is never deleted in normal circumstances until de-installation or cache cleaning.
Even if the cache is cleaned (properly), those files are re-installed the next time you start Kodi.
I'm pretty sure not only this file is deleted somehow, btw.
Might be some "smart" cleaning process on you box that deletes cached files when running out of disk space?
Not really.
It has plenty of free space.
In fact I just have it for kodi, but I am getting worried.
When a movie freezes for any reason, I might not be able to start kodi again.
Many times when kodi is running well I cannot even exit the program, it stays with the exit box there...
The android version is stable?
Mine isn't working either. I reinsalled but it's been crashing without any improvement. Please help. Thanks.
Try clearing the cache in Android settings > Apps > Kodi. I had the same problem and that worked for me.
