I've got Kodi running on my FireTv and while watching a video and hitting the return button the video doesn't stop playing, however Kodi continues back to the previous menu.
Is this a remote issue? I've never had a problem with my AppleTv's doing this..
Ideas or solutions anyone?
Ampapa,
Cant you just use the pause button on the remote?
That will pause the movie not exit the movie..
I am still newer to this so someone might have a better answer than me but when your playing the movie and you push the center button, you can select stop. That is the only way I have found to stop it. Hopefully someone can tell you something that will work better for you.
ned Scott
Would you mind creating a sub-topic in the wiki somewhere specifically explaining how to change the keymap for <back> from <fullscreen> to <stop> in the fullscreen video section, so that we can link to it, please.
Thanks guys just wha tI was looking for...
Ampapa,
Hi Guys
I want to set the remote file...wich shall i choose remote.xml like remote of appletv2.
You can name it anything as long as it ends with .xml
Hoe van i put THE file in the map?
You can use the
file manager (wiki) to copy it over from a network share.
