Full Version: Scraping issues - cURL error 56
Any help would be appreciated !
My XBMC installs keep experiencing errors when I update library - it affects both the MovieDB and the TVDB. It started with missing thumbnail art, a refresh used to fix it.
Now the update scrapes and does not add anything new - to compound this issue sometimes everything works - no rhyme or reason. Naming convention for movies and episodes is correct.
The setup has been stable for 18+ months - issues have become more apparent since early January. I can occasionally add the items manually.
Setup is below
XBMC 12.3
Windows 7
Synology 412+ NAS
Here is the error from the debug log
17:47:27 T:2760 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 56
17:47:27 T:2760 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
17:47:27 T:2760 ERROR: ADDON::CScraper::Run: Unable to parse web site
Complete debug log below
http://pastebin.com/SB921vLj
Library updates on two iOS devices yield same results. XBMC shows as connected to the internet. I can't see it being XBMC - has to be network or IP issues. Could it be an issue with cURL ?
Anybody have any ideas ?
The issue is so sporadic - a regular library scan adds a few items (minus artwork) a manual scan sometimes works after a XBMC reboot.
