Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
(2015-02-14, 15:59)bertybassett Wrote: [ -> ] (2015-02-14, 02:14)username145 Wrote: [ -> ]Since I bought a Pi 1 like a week before the Pi 2 came out (Pi 2 on back order for March), decided to see how it runs as a PVR backend and client on Raspbmc, while recording to a NAS over wifi. It did surprisingly well, no problems at all. Only issue is UI sluggishness. Simply scrolling the EPG timeline, for example, or even navigating menus during playback, is quite choppy. If this choppiness does not exist with the Pi 2, I'll order 3 of them :P
here is my tube video of a fully set Raspberry Pi 2 with Aeon Nox with OPENelec and TVheadend and the guide going insanely fast and smooth.
Live TV bits are near the end.
P.S. don't forget the advancesettings.xml with <algorithmdirtyregions>3</algorithmdirtyregions>
https://www.youtube.com/watch?v=jjqEj0ArQEg
That looks really impressive thanks for posting. Can I ask a couple of questions.
1. Is your Pi2 Overclocked?
2. Do you have the TV Headend server running on Pi2 or on another computer?
3. Have u purchased the MPEG2 codec?
4. What is CPU percentage when watching live tv
For those that already have a unit, does software decoding of DTS core work? I had to give up on my previous Pi because most Blu-Ray rips have DTS instead of AC3 and I would constantly get stuttering. I am hoping that the Pi 2 will now be able to play these files and I can stop plugging my laptop into my TV.
P-Worm
Yes. On a Pi2, software DTS decoding to PCM works, as I believe does software Dolby True HD decoding.
(2015-02-15, 19:14)noggin Wrote: [ -> ]as I believe does Dolby True HD decoding.
Confirmed.
(2015-02-15, 13:50)RageCrap Wrote: [ -> ] (2015-02-14, 15:59)bertybassett Wrote: [ -> ] (2015-02-14, 02:14)username145 Wrote: [ -> ]Since I bought a Pi 1 like a week before the Pi 2 came out (Pi 2 on back order for March), decided to see how it runs as a PVR backend and client on Raspbmc, while recording to a NAS over wifi. It did surprisingly well, no problems at all. Only issue is UI sluggishness. Simply scrolling the EPG timeline, for example, or even navigating menus during playback, is quite choppy. If this choppiness does not exist with the Pi 2, I'll order 3 of them
Would you mind sharing your setup?
NFS - SMB?
Advanced settings
sd card brand-type
overclock...
You system is very responsive. At the moment i use confluence en my system is not as responsive!
Hello guys, i use 1080XF and it works like a charm on the new raspberry pi 2 oc to 1000ghz, the main problem is that if i leave it on stand by for a long period it freezes and needs a reboot.
(2015-02-16, 09:15)abpostelnicu Wrote: [ -> ]Hello guys, i use 1080XF and it works like a charm on the new raspberry pi 2 oc to 1000ghz, the main problem is that if i leave it on stand by for a long period it freezes and needs a reboot.
Remove the overclock and see if the freeze stops.
Will do that and let you know. Another issue that i've encountered is when changing to the new skin 1080xf my library was no longer present and no scrapping was done..
Way to much...
(2015-02-16, 15:36)Memphiz Wrote: [ -> ] (2015-02-16, 09:15)abpostelnicu Wrote: [ -> ]Hello guys, i use 1080XF and it works like a charm on the new raspberry pi 2 oc to 1000ghz, the main problem is that if i leave it on stand by for a long period it freezes and needs a reboot.
Way to much...
How can that be way to much since the default speed is 900mhz?
because its more then factor 1000 man ...
(2015-02-16, 15:37)abpostelnicu Wrote: [ -> ] (2015-02-16, 15:36)Memphiz Wrote: [ -> ] (2015-02-16, 09:15)abpostelnicu Wrote: [ -> ]Hello guys, i use 1080XF and it works like a charm on the new raspberry pi 2 oc to 1000ghz, the main problem is that if i leave it on stand by for a long period it freezes and needs a reboot.
Way to much...
mhz vs ghz
sorry for the misspelled word
i have put a smiley behind my statement - didn't think that this ended up in a bubblegum
