(2015-07-27, 04:31)arithine Wrote: [ -> ]I'm not sure if it's dependent on any addon, except maybe artwork downloader, but I'm the one who took that screenshot, what I did was create a collection called "Marvel Universe" and added all my Marvel movies into it (this is built in to kodi http://kodi.wiki/view/Movie_sets) then I went into the context menu, selected "manage" then "choose art" and added some artwork I found online. For the logo (I actually don't think this skin supports logos, but exploaded does) you have to select "add art" and name it "clearlogo" (after which all of my collections had that added to them). Also the disks shown at the bottom are only in exploded.
script.skin.info.service is needed to display infos about movie sets (plots etc.) - which now that I double checked I already did implement.
https://github.com/phil65/script.skin.info.service
This skin does support clearlogos - the option is in Skin Settings > Furniture
where can i download the weather fanart?
I'm seeing horizontal banding artifacts, which move/change during animations, example here:
https://i.imgur.com/1XWLABv.jpg
The background I'm using is here, if it matters:
https://i.imgur.com/lRAJvCg.png
Think it might be a bug in Kodi, or skin specific? Running on a Pi 2, Isengard, latest git version of the skin
Also, is there any way to turn off background fan art completely? When using widgets like spotlight/recent episodes for movies and TV shows, fan art in the home menu is displayed, even though it's turned off in the settings and the "customize home" menu.
Cheers!
jurialmunkey : In last git you have fixed albums widgets with classic home screen and button up enabled to show widget. But not for favourites.
(2015-07-27, 12:33)Guilouz Wrote: [ -> ]@jurialmunkey : In last git you have fixed albums widgets with classic home screen and button up enabled to show widget. But not for favourites.
Unfortunately, this pretty much cant be fixed without being excessively complicated.
Hey, I just installed the theme and played around with it. I noticed some inconsistency:
First the menu of video and music playback is completely different. This really annoys me. First it should look at least similar. Also on video playback the menu doesn't open when I press menu2 on my IR remote, only when pressing pause. Also after resuming some black bars stay visible for 10 seconds before they disappear again.
Also the overlay background of home screen and music playback screen differs. Would be cool if I could customize this overlay anyway.
Also some text labels are overlapping:
For example in movie view media info with extra info. If the directors name is to long it overlaps with the runtime. Or in music playback screen the next song title overlaps with the runtime label.
(2015-07-27, 05:35)jurialmunkey Wrote: [ -> ]script.skin.info.service is needed to display infos about movie sets (plots etc.) - which now that I double checked I already did implement.
Does script.skin.info need to be installed manually? I can't see it in the repo
The Now Playing Queue is accessible from the OSD, thanks for that! However, there is no option to change View or Sort By in the context menu. (I'm no so concerned about the changing the View, but Sort By is currently showing the ugly filenames.)
Cheers
(2015-07-27, 10:57)username145 Wrote: [ -> ]I'm seeing horizontal banding artifacts, which move/change during animations, example here: https://i.imgur.com/1XWLABv.jpg
The background I'm using is here, if it matters: https://i.imgur.com/lRAJvCg.png
Cheers!
Fixed the banding, fan art problem, and got a *huge* speed-up in animation/smoothness on my Pi 2 by replacing bg.jpg with an 8x8 pixel png
(2015-07-28, 00:50)bigwillch Wrote: [ -> ] (2015-07-27, 05:35)jurialmunkey Wrote: [ -> ]script.skin.info.service is needed to display infos about movie sets (plots etc.) - which now that I double checked I already did implement.
Yes, download and install from zip
I'm probably doing something wrong and can't figure it out.
I lost my hard drive and had to reinstall everything. I remember that when you used the extendedinfo script, it would identify movies in your collection with a "play" button. I can't find how to activate it, unless it is a change on the skin
(2015-07-28, 04:33)username145 Wrote: [ -> ] (2015-07-27, 10:57)username145 Wrote: [ -> ]I'm seeing horizontal banding artifacts, which move/change during animations, example here: https://i.imgur.com/1XWLABv.jpg
Cheers!
Spoke too soon... the banding re-appears when browsing the skin whilst playing a video
i would like to set this widget to the weather menu:
for this is no weatherpath neccesary right? Cant configure it to show this
Sorry for my stupidness
It's necessary to set path for weather fanart in skin settings to show this weather widget.
