What size picture should we be using for our shortcut backgrounds on the home screen? Whatever mine are, they are stretched, and real blurry.
(2015-10-11, 04:37)jurialmunkey Wrote: [ -> ] (2015-10-11, 02:13)Magic815 Wrote: [ -> ] (2015-10-10, 23:45)jurialmunkey Wrote: [ -> ]1. That is strange. Not a skin issue though.
You sure? I'm not having that issue on any other skin.
Yep 100% sure. Skins don't control what content is in a list container supplied by nodes/library/filelist etc -- skins only control how that content is displayed. For instance, I could use a stringcompare condition to change the label to say "Add Purple Monkey Dishwashers...", but I could never actually remove the item from the list.
My guess is you have disabled them in settings.
Settings > Appearance > Show "Add Source" buttons
When disabled it will only show when you have no sources -- once you add a source it will not show any more.
like you said this is likely a kodi issue but i've noticed this bug as well. i have files as a submenu entry and whenever i enter it add sources is missing. with confluence clicking files under the video menu populates it correctly. oddly, if i go into files in a:z, switch to confluence, and then go into files, add sources is missing. i need to back out and enter it a couple of times before it shows up.
if, in a:z, instead of going through the files submenu entry i go in through videos and then click files it is populated correctly. honestly it's not like i'm adding sources that often that it really matters to me. although i have noticed that when the add sources option is missing the edit sources context menu entry is missing. but again that's a kodi bug and not something i do very often.
for those asking for jarvis updates, i'm running a nightly build from last week and haven't had any issues. ymmv. the annoying bug where it would take two tries to switch back to confluence if you aren't on the default color scheme has been eliminated. although switching back to a:z still results in the default color scheme being selected, but that's another kodi bug not related to the skin.
Hey man, first of all i love your skin.
I have only one issue, i did a clean install from your zip and get this error:
"Skin shortcut, unable to build menu"
So before i come here ask for help, i reinstall, delete roaming folder, and try install from kodi repository, still show me the same error.
Do you have any idea what this is?
I have Kodi Isengard install it, i reinstall it too. Windows 8.1
I search here in this post and in your forum but nothing come up how to resolve this issue.
Plus i try to do the logs with kodi log uploader but dint work, dint send me the email with the logs.
Any help?
You say you installed Arctic from zip, so you got it from github, right? Since I'm not sure exactly what version of Arctic you have installed, I would just install the latest skinshortcuts from github...my guess is that will resolve your issue regardless of what skin version you are using.
Update: Best to follow Bob's instructions on this one, he's the expert on all things skinshortcuts.
Hello,
I love this skin it is just perfect!
However I meet big one concerns, it is impossible to me to reach on the menu of customization, nothing takes place when I click above...
It is certainly a minor problem but if somebody could well help me to free this situation!
Thank you in advance!
Hi all,
I made a build using your skin eveything works great except one little thing.
The background images are set to a location instead of a special path: so when i install it on another device the background images are not loaded. I edited the proporties file but it doesnt seem to be the correct loacation.
I used the media directory in the kodi directory to store my images. I will post part of the content of the file here so hope somebody knows the correct path or the correct way of entering it been busy for days and searching the forum didnt do the trick.
mainmenu', 'series', 'widgetName', u'Populaire TV series'],
['mainmenu', 'series', 'widget', u'PopularTvShows'],
['mainmenu', 'series', 'translatedPath', u'ActivateWindow(10025,"plugin://plugin.video.genesis/?action=tvNavigator",return)'],
['mainmenu', 'speelfilms', 'widgetName', u'In bioscopen'],
['mainmenu', 'speelfilms', 'widget', u'InCinemas'],
['mainmenu', 'plugin.audio.mp3streams/', 'translatedPath', u'ActivateWindow(10501,"plugin://plugin.audio.mp3streams/",return)'],
['mainmenu', 'plugin.audio.mp3streams/', 'background', u'/storage/external_storage/sdcard1/b/.kodi/media/music.jpg'],
['mainmenu', 'plugin.audio.mp3streams/', 'backgroundName', u'/storage/external_storage/sdcard1/b/.kodi/media/music.jpg'],
['mainmenu', 'trakt', 'translatedPath', u'ActivateWindow(10025,"plugin://plugin.video.genesis/?action=tvshows&url=traktcollection",return)'],
['mainmenu', 'trakt', 'background', u'/storage/external_storage/sdcard1/b/.kodi/media/video.jpg'],
['mainmenu', 'trakt', 'backgroundName', u'/storage/external_storage/sdcard1/b/.kodi/media/video.jpg'],
['mainmenu', 'sport', 'background', u'home://media/sports.jpg'],
['mainmenu', 'sport', 'backgroundName', u'home://media/sports.jpg'],
['mainmenu', 'livetv', 'translatedPath', u'RunScript("script.extendedinfo")'],
['mainmenu', 'livetv', 'background', u'"home://media/tv.jpg"'],
['mainmenu', 'livetv', 'backgroundName', u'"home://media/tv.jpg"'],
['mainmenu', '"script.extendedinfo"', 'background', u'/storage/external_storage/sdcard1/b/.kodi/media/playlist.jpg'],
['mainmenu', '"script.extendedinfo"', 'backgroundName', u'/storage/external_storage/sdcard1/b/.kodi/media/playlist.jpg'],
['mainmenu', '"script.extendedinfo"', 'translatedPath', u'RunScript("script.extendedinfo")'],
['mainmenu', 'script.navi-x', 'translatedPath', u'RunAddOn(script.navi-x)'],
['mainmenu', 'script.navi-x', 'background', u'/storage/external_storage/sdcard1/b/.kodi/media/navix.jpg'],
['mainmenu', 'script.navi-x', 'backgroundName', u'/storage/external_storage/sdcard1/b/.kodi/media/navix.jpg'],
['mainmenu', 'kids', 'background', u'/storage/sdcard0/Android/data/org.xbmc.kodi/files/.kodi/media/addons.jpg'],
['mainmenu', 'kids', 'backgroundName', u'/storage/sdcard0/Android/data/org.xbmc.kodi/files/.kodi/media/addons.jpg'],
['mainmenu', 'plugin.video.youtube', 'translatedPath', u'ActivateWindow(10025,"plugin://plugin.video.youtube",return)'],
['mainmenu', 'plugin.video.youtube', 'background', u'/storage/external_storage/sdcard1/b/.kodi/media/youtube.jpg'],
['mainmenu', 'plugin.video.youtube', 'backgroundName', u'/storage/external_storage/sdcard1/b/.kodi/media/youtube.jpg'],
['mainmenu', 'programmas', 'background', u'/storage/external_storage/sdcard1/b/.kodi/media/programs.jpg'],
['mainmenu', 'programmas', 'backgroundName', u'/storage/external_storage/sdcard1/b/.kodi/media/programs.jpg'],
['mainmenu', 'settings', 'background', u'/storage/external_storage/sdcard1/b/.kodi/media/launcher.jpg'],
['mainmenu', 'settings', 'backgroundName', u'/storage/external_storage/sdcard1/b/.kodi/media/launcher.jpg'],
['mainmenu', '33060', 'background', u'/storage/external_storage/sdcard1/b/.kodi/media/gandelfkodibackgrounds/shutdown.jpg'],
['mainmenu', '33060', 'backgroundName', u'/storage/external_storage/sdcard1/b/.kodi/media/gandelfkodibackgrounds/shutdown.jpg']]
In the TV background you can see one of my attempts. Normal location was sdcard1
Thanks in advance
