2015-03-07, 02:12
(2015-03-07, 00:19)DruTheFu Wrote: [ -> ]Out of curiosity, what's the average time that this skin gets updated in the official repo once the updates hit the git?It depends on when I send a PR and the time it takes to get accepted -- some basic checks need to be run before updates are accepted. There are also rules regarding not sending too many updates to official repo to avoid excessive strains on servers and constant downloads on the user end. I send a PR about every 1-2 weeks after testing changes as per addon rules: http://kodi.wiki/view/Add-on_rules#Updates
(2015-03-07, 01:39)furii Wrote: [ -> ]Yep only makes a change if you are using the light theme. Need to add a check to only enable the control if light theme is selected.(2015-03-07, 01:26)colbert Wrote: [ -> ]In skin settings > OSD > Use dark theme, is that the OSD during video playback when you hit info/pause/menu? I can't see any difference with it on or off so just checking (I don't use Music section in Kodi so if it's for that that explains it)i believe that just turns on the dark osd if you're using the light theme or dark theme with light dialogs.
(2015-03-07, 01:26)colbert Wrote: [ -> ]Any possibility to allow different views for the addons that aren't set as movie/tv/episodes?
What addons? I haven't really encountered any add-ons that dont set a content type for video content -- if its a video addon then it should set a content type for its videos -- if it doesn't then this should be taken up with the addon author. If I enable them regardless of content type then I just end up with a flood of complaints about scaling/aspect issues so I enforce strict content type rules for the views.
