(2015-03-07, 09:19)VelvetKevorkian Wrote: [ -> ]I don't know if it has been mentioned before, but in a music playlist, the currently playing song is not highlighted in any way.
Added a play indicator on git.
(2015-03-07, 11:47)pseudoheld Wrote: [ -> ]just updated to the latest github version.
a few observations:
1. i preferred the simple circle loading animation. the "flower" loading icon seems kinda out of place with the rest of the minimal design. (maybe as an option? im sure some people like the flower...)
2. when viewing the seasons of a tv show would it be possible to disable the plot? its the same for every season anyhow (at least for me) so its kinda redundant. would like the big symbol view to only show the season name without the plot.
3. can we have numerical rating instead of "stars" rating for movies and tv shows? I much prefer seeing that a movie has 7,5 as rating instead of 3 full and one half full star
4. somewhat offtopic: is there any way to refresh the ratings for a movie. i just noticed that i was scraping the ratings from tmdb although i normaly prefer imdb. i switched the ratings source in the addon however can i now somehow invoke an update of all the ratings or would that mean rescraping my whole library??
1. Definitely will be some options - I'm thinking that I will make it so users can just browse and select a different gif if they want (and I'll provide a few options in the extras folder).
2. I know what you are saying. I'm kinda hoping that one day we will get season specific plots. This is something I'll need to think about as I'm sure plenty of people like having the plot here for seasons and I'm a bit wary of adding too many extra options at this stage -- plus if I was going add an option here it would be to disable all the text completely rather than just the plot specifically.
3. All the list type views show numerical rating. My perspective on this is that you choose the viewtype on the basis of how much information you want to see -- the icon views are more visual where as list views are more textual. Once again, its one of those things where I'm wary of adding an too many options
4. There is an addon for that:
http://forum.kodi.tv/showthread.php?tid=167754
(2015-03-07, 13:26)hacky4real Wrote: [ -> ]Could you change the text "internet video" on the video OSD to "Now streaming".. I think it's better that way
I changed it to "Video Stream" so its a little less ambiguous than "now streaming".
(2015-03-07, 13:59)magy77 Wrote: [ -> ]where can i find this var: $VAR[PlayerTitle]
Includes_Labels.xml
(2015-03-07, 15:56)Woppie Wrote: [ -> ]Maybe you can add the group name just like the mini guide window where it's in the top left corner?
Appending it vertically on the left before the channel numbers or on the right after the program info might look good, or on the right bottom corner under the starting/ending time or just in the top left where it says sorting: on name. Instead of the label "Live TV" like now it would be better to display "Timeline: Active Channel Group". Just some ideas about it that might work out.
One small bug remains; the channel group only gets displayed when the pvr is on; else it won't. Maybe you know how to fix that for $INFO[VideoPlayer.ChannelGroup]
Yeah VideoPlayer.ChannelGroup is just whatever group the currently playing channel belongs to. Not really what we want here. Basically you have to grab the label of channel group switcher with Control.GetLabel(28)
I've added it to the sublabel of the header (after "sorting: by name")
The Icon in the header is staying as LiveTV - the point of it is to show you what part of Kodi you are in - Movies Library, TvShow Library, PVR, Music, Programs, Pictures, Settings etc.
However, I do agree the text needs to be changed to indicate what part you are in (can be confusing if its timers/recordings/channels).
Changed on git.
(2015-03-07, 17:19)hoopsdavis Wrote: [ -> ]Jurial, is it possible to show the shows or movie image in the EPG guide?
I didn't even know that was possible... definitely doesn't work with all backends. Are those actual screenshots from 1080xf or are they just mockups?
(2015-03-07, 18:25)Edworld Wrote: [ -> ]Jurialmunkey:
More of a comment than a request:
I like the way you implemented extendedinfo on dialoginfo screen. Not sure if you are interested in showing what movies are inu your database or not
Extended info always shows movies that are in your library first. In the github version of the skin it now shows a play icon over the big poster if you can play it from your library. You can then press up to highlight the play icon and click to play.
(2015-03-07, 18:36)thrak76 Wrote: [ -> ]An omission I just noticed regarding music visualization: There are no settings to be had. You can choose between which visualization engine, and the presets, but you can't adjust settings. Time between presets, random times, hard cuts, etc..
I don't adjust those settings very often which is why I only noticed it now.
Yeah I don't really have a spot for it on the osd. You can change the settings from Settings > Addons > Enabled Addons > Visualisations (not convenient I know...)
(2015-03-07, 20:33)Edworld Wrote: [ -> ]Jurialmunkey:
Not sure if this is working as intended. After I select a movie, cast, and I choose director, I don't get his Bio or any other information that appears when I select an actor. Instead of all the personal info, I get: Director, similars, and Studio.
I hope my description helps
Yeah this is intended. The problem with extendedinfo dialog is that it shows the movies that the director had acted in rather than directed. I did it that way because I find that when I click on a director I'm interested in seeing what other movies they directed (the similar/studio is just a bonus thing that is possible with extendedinfo).
I'm trying to think of a way to incorporate both elements -- I'm thinking maybe an additional button in the left menu of the videoinfo that goes to that screen (e.g. a Similar Movies button) and then have the director button in the cast still open the info dialog like other cast members.
(2015-03-08, 00:38)xbmclinuxuser Wrote: [ -> ]In Skin Settings: Home, "Show weather" is greyed out and it appears there is no way to see the weather in this skin, in other words there is no "Weather" selection in the main menu. What am I missing? Running Kodi 14.1 on Ubuntu Linux 12.04.
That option shows a weather widget in the top right corner. It is grayed out because you have selected to show the weather with the clock so it is unnecessary to show it twice.
For menu items you can configure the whole menu in Skin Settings > Home > Customise home menu -- click choose shortcut > Common and weather is in there.
