2015-04-06, 17:16
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216
2015-04-06, 17:16
2015-04-06, 19:00
Hey jurial,
The trailers in (in cinema) are all in english. Any chance to change this over kodi language option?
2015-04-06, 21:12
Just checking, but I went through all the views and (talking Movies section here) Media info with Extra Info checked seems to be the only way to see runtime, any possibility to add that to other views? I don't know about others but runtime is a much more useful bit of info than say, rating. Thanks for your help !
2015-04-06, 23:11
(2015-04-06, 11:42)bigwillch Wrote: [ -> ](2015-04-06, 09:27)meridius Wrote: [ -> ]also would love a option when you hit play it would bring up a very similar window to the one when you push (i) on the keyboard but with just the options play, cast, trailer and nothing else that would be excellent
If kiosk mode is enabled and the default kodi play action is set to show info this is exactly what already happens
well not really, it does do similar to what I suggested but there is no discart and extrathumbs and no trailers plus the play would be better at the top and then cast, I know what you mean but this is why I suggested what I did as its just about there apart from trailers and the discart and extrathumbs
what is cinema experience ? by the way
2015-04-07, 04:47
(2015-04-06, 09:41)nickr Wrote: [ -> ]Personally I prefer the term AC3 to Dolby Digital. Both are correct IMHO. Also I think TrueHD is OK without adding "Dolby" before it. Space is sometimes at a premium.These labels are set by kodi. I could match with a variable but I think its a bit of a waste of time to be honest. The only use case for codec info that I'm aware of is passthrough audio to a receiver as some receivers dont support all codec types or have specialised settings for certain codec types (e.g. Dolby vs DTS) - so I don't think its that big of a deal as you can still tell what codec it is and different regions are going to have their own variants of some anyway.
(2015-04-06, 15:25)Abu-Dun Wrote: [ -> ]Great skin! Any chance of adding a banner view for TV shows,Possibly in the future but I dont have time currently for new features.
(2015-04-06, 15:29)DruTheFu Wrote: [ -> ]I know you have a ton going on in and out of the skinning world, but I'm wondering I can make a feature request for the Home screen Spotlight. I know there are some default, canned Spotlight widgets you have already implemented with this skin, but I'm wondering if you can add one to cycle through random movies AND random episodes in a single Spotlight widget? Right now it's currently one or another. I think it would be nice to see a Spotlight of both of these libraries at the same time, randomly.Unless I'm misunderstanding, what is wrong with adding the path for the combined widget as a custom widget path then adding the custom widget to the menu item? (Customise > Select Widget > Custom 1)
(2015-04-06, 17:16)Razze Wrote: [ -> ]I know I brought it up before, but it still bothers me. The runtime is missing on every item on the home screen, at least on my rPi2 openELEC. The windows one has it with some exceptions.Yep library data provider. Its strange how I never seem to have problems with it but heaps of others do
Are these also from service.library.data.provider?
(2015-04-06, 19:00)magy77 Wrote: [ -> ]Hey jurial,Controlled by extended info script.
Settings > Addons > Enabled Addons > Helper Addons > Extended Info > Configure > Language for the MovieDB requests
(2015-04-06, 21:12)colbert Wrote: [ -> ]Just checking, but I went through all the views and (talking Movies section here) Media info with Extra Info checked seems to be the only way to see runtime, any possibility to add that to other views? I don't know about others but runtime is a much more useful bit of info than say, rating. Thanks for your help !Should be way more views than that: List, Wide, Big Wide, Cards, Extra Info, Media Info
The only ones that dont are Icons, Big Icons, Thumbs, and Big List
Though I do have a change coming to the flags (on git) that will show duration instead of video codec for those views that don't have a duration in the list.
(2015-04-06, 23:11)meridius Wrote: [ -> ]what is cinema experience ? by the wayAn addon that shows trailers and things like that before playing the movie to give a feeling of being at the cinema.
2015-04-07, 09:34
1) The video addon "dokumonster.de" (german documentaries) allows only the views "Big wide" and "Preview" for the video list. Probably an issue of the addon and not your skin. Do you see any easy fix?
https://github.com/dersphere/plugin.video.dokumonster
2) Any chance to add an option to move the small "Loading..." spinner to the right corner without the text? I think it would be more smooth than the text and dark background with every new page.
Or someone has any other nice idea for a small loading indicator.
2015-04-07, 09:49
(2015-04-07, 04:47)jurialmunkey Wrote: [ -> ](2015-04-06, 17:16)Razze Wrote: [ -> ]I know I brought it up before, but it still bothers me. The runtime is missing on every item on the home screen, at least on my rPi2 openELEC. The windows one has it with some exceptions.Yep library data provider. Its strange how I never seem to have problems with it but heaps of others do
I'm not sure why. Which systems are you using? MySQL Backends? (All data helps)
Could be service.library.data.provider or any scrapper filling the database.
I'll try to look into it later today.
2015-04-07, 11:06
(2015-04-07, 09:34)namtih Wrote: [ -> ]1) The video addon "dokumonster.de" (german documentaries) allows only the views "Big wide" and "Preview" for the video list. Probably an issue of the addon and not your skin. Do you see any easy fix?1. what views are available depends on what content type the addon sets -- no content only get big list and thumbnails. If it sets as episodes then you get all views that have landscape artwork. If it sets as movies then you get all views.
2. This is a case of damned if you, damned if you dont. In eminence I had a small spinner in the corner and I get complaints that its not obvious enough and should be centered on the screen. In this skin people complain about it being the other way around! I think having an option for this is excessive - this is something that will have to be left up to user mods.
(2015-04-07, 09:49)Razze Wrote: [ -> ]OpenELEC on the htpc, Fedora on the laptop. OpenELEC machine has local files on usb drives, standard local library database and uses Universal Movie scraper (though no problems when I was using default moviedb scraper either - just switched for imdb top250 stuff). Laptop has local database with content via samba.(2015-04-07, 04:47)jurialmunkey Wrote: [ -> ](2015-04-06, 17:16)Razze Wrote: [ -> ]I know I brought it up before, but it still bothers me. The runtime is missing on every item on the home screen, at least on my rPi2 openELEC. The windows one has it with some exceptions.Yep library data provider. Its strange how I never seem to have problems with it but heaps of others do
Nothing fancy, no shared databases or NAS storage or anything like that.
2015-04-07, 16:13
(2015-04-07, 04:47)jurialmunkey Wrote: [ -> ](2015-04-06, 15:29)DruTheFu Wrote: [ -> ]I know you have a ton going on in and out of the skinning world, but I'm wondering I can make a feature request for the Home screen Spotlight. I know there are some default, canned Spotlight widgets you have already implemented with this skin, but I'm wondering if you can add one to cycle through random movies AND random episodes in a single Spotlight widget? Right now it's currently one or another. I think it would be nice to see a Spotlight of both of these libraries at the same time, randomly.Unless I'm misunderstanding, what is wrong with adding the path for the combined widget as a custom widget path then adding the custom widget to the menu item? (Customise > Select Widget > Custom 1)
Thanks for the reply.
In a previous post, you suggested using the code:
plugin://service.library.data.provider?type=randommovies+randomepisodes&reload=$INFO[Window.Property(randommovies)]$INFO[Window.Property(randomepisodes)]
I created "Custom 1" using this suggested code within Settings > Skin Settings > Widgets, but I don't see where/how to implement this to the "Home" screen Spotlight. I figured out that I can implement this to Home screen menu items (i.e. "Movies", "TV Shows", etc), but I haven't figured out how to do this for the overall Home screen Spotlight specifically.
Maybe I'm missing something....
Thanks for your continued help.
2015-04-07, 19:40
Any way to have weather has the widget on main menu? I have no widgets on any item (Movies, TV, etc.) so I'm in skin settings > customise main > Widgets, could I put something in Custom widget 1 and have weather just stay on the main menu then as the widget? I don't find the default widget scrolling through movies to be useful for me so just checking, thanks !
2015-04-07, 21:02
(2015-04-07, 16:13)DruTheFu Wrote: [ -> ]Are you saying that you want it in the selector at the top of the screen? I dont see much point to that because you can just change between them there anyway?(2015-04-07, 04:47)jurialmunkey Wrote: [ -> ](2015-04-06, 15:29)DruTheFu Wrote: [ -> ]I know you have a ton going on in and out of the skinning world, but I'm wondering I can make a feature request for the Home screen Spotlight. I know there are some default, canned Spotlight widgets you have already implemented with this skin, but I'm wondering if you can add one to cycle through random movies AND random episodes in a single Spotlight widget? Right now it's currently one or another. I think it would be nice to see a Spotlight of both of these libraries at the same time, randomly.Unless I'm misunderstanding, what is wrong with adding the path for the combined widget as a custom widget path then adding the custom widget to the menu item? (Customise > Select Widget > Custom 1)
Code:plugin://service.library.data.provider?type=randommovies+randomepisodes&reload=$INFO[Window.Property(randommovies)]$INFO[Window.Property(randomepisodes)]
(2015-04-07, 19:40)colbert Wrote: [ -> ]Any way to have weather has the widget on main menu? I have no widgets on any item (Movies, TV, etc.) so I'm in skin settings > customise main > Widgets, could I put something in Custom widget 1 and have weather just stay on the main menu then as the widget? I don't find the default widget scrolling through movies to be useful for me so just checking, thanks !There are a couple of different options. If you set the slideshow path then the default widget wont show. Then you can select show weather widget from home options. Alternatively you can set individual backgrounds/slideshows for each menu item individually. The last option is if you set weather fanart in skinsettings > backgrounds then set each individual menu item widget to weather in the home customisation screen. Each eay acheives a slightly different result in terms of what is displayed as the background.
2015-04-07, 21:27
Is TVheadend PVR backend supported on this skin? I'm looking to buy a MOI+ PVR box that runs it, but want to ensure I'll be able to use the PVR fully. (set timers etc.)
2015-04-07, 21:37
Yep I use tvheadend on openelec
2015-04-07, 23:07
@jurialmunkey
Hi there, did you look at my post 1087 ? as you did not respond to it. wanted to know your thoughts on that about the codec of the audio flags and discart
thanks
thanks
2015-04-07, 23:19
(2015-04-07, 23:07)meridius Wrote: [ -> ]@jurialmunkey
thanks
I think 1100 deals with it? (Via a response to my response to you).
