2015-02-03, 17:08
Hey There Everyone,
Got a question, thought this would be the place to ask.
I have a generic remote for my android 4.4 box that's running XBMC with the Launcher from the start. Here's a photo of the controller on the left: http://ecx.images-amazon.com/images/I/51...SX425_.jpg
When I'm using the device, and touch the Home button, the system seems to reset itself (it's the button in the upper left with the house...duah). What I'd like that button to do is to take me directly to the XBMC home screen without resetting the system (like when you press Tab on a keyboard).
I've used the Keymap Editor for some of the other buttons, but the issue with the Home button is that when you use it (to try to figure out what code # it is), the system restarts, and doesn't record the change.
I'm not super technically inclined, but my next step will be to use the debugging log and then go through and look at all the buttons when I press Home.
Anyways, if anyone has some advice about how to reprogram the Home button, that'd be great.
Cheers.
Cheers.
