Full Version: How to update Kodi and ONLY KODI
Hi all,
I've Kodi 14.0 on my Linux system and I'd like to upgrade it to 14.1. I know the procedure should be:
sudo apt-get update
sudo apt-get upgrade
My problem is that by doing it I not only update kodi but all programs, and by doing it I get some problems on my system (there is some software I've that makes problems when update).
Question is, how can I update KODI and ONLY Kodi?
Many thanks in advance
Look at sudo apt-get install --only-upgrade <package> - this will only install upgrades to the named package, and won't install anything new. Try only-upgrade Kodi* - it might get you what you need.
