2015-02-06, 17:57
Hi.
I got a new full HD TV that I have connected via HDMI to my PC. Kodi is mostly what got the TV for. HDMI resolution I set to 1080p@60hz via amd ccc.
In kodi resolutions I have two 1920x1080p options. One at the top and one 2nd to bottom above 1920x1080i
If I choose the first one the UI is fluid but the video playback does not look as sharp as in plexi Smart tv app. Also the TV identifies the output as 1920x1080@60hz.
If I selected the other one the video looks the same as in plexi but the UI gets slow and very annoying.
Do you guys know how can I get the best of both worlds? I really want to use kodi instead of plexi as it would be a pain to keep disconnecting and connecting the pc speakers.
System specs
I5 4670k
2x4gb ram
And r9 280x
Thanks a lot
System specs
I5 4670k
2x4gb ram
And r9 280x
Thanks a lot
