2015-02-07, 09:47
Hello there.
i am using the twitch-Plugin for kodi and it stopped working since today.
i can select the stream and press play, then it will do the standard "start playback" thing and then it says working on the bottom right side for about 2 minuts. then i get an error saying i should look into the login file, witch can be found here:
http://pastebin.com/ch4JZwVU
As you can see its spamming something like ERROR: CCurlFile::GetCookies - invalid cookie:
I tryed: Update Windows, Update Graphicsdriver, Update to the newest Kodi Version, reinstall the twitch plugin (settings werent removed i guess)
After this i posted it on the github site from the developer, and they said that the plugin did the work properly, shown by this massage:
05:56:26 T:2820 NOTICE: DVDPlayer: Opening: http://video3.fra01.hls.twitch.tv/hls8/b...99de3d1528
Link to github issue: https://github.com/StateOfTheArt89/Twitc...issues/112
Can you help me? thx!
