2015-02-07, 13:54
Can someone compile a Kodi ARM Linux build for Rockchip RK3288 Firefly board?
RK3288 Firefly board supports Open GL/GLES OpenCL Mali T764 hardware acceleration with framebuffer driver.
I compiled XBMC Android a year ago, but it was running very slowly and video playback was like a slideshow.
Also takes very long on my slow PC.
What are the correct ./configure options to use to make Kodi run optimally and fast.
Found the below options in another forum.
./configure --prefix=/usr --build=arm-linux-gnueabihf --host=arm-linux-gnueabihf
--localstatedir=/var/lib --with-platform=raspberry-pi --disable-gl --enable-gles
--disable-x11 --disable-sdl --enable-ccache --enable-optimizations
--enable-external-libraries --disable-goom --disable-hal --disable-pulse
--disable-vaapi --disable-vdpau --disable-xrandr --enable-airplay --disable-airtunes
--disable-alsa --enable-avahi --enable-libbluray --enable-dvdcss
--disable-debug --disable-joystick --enable-mid --enable-nfs --disable-profiling
--disable-projectm --enable-rsxs --enable-rtmp --disable-vaapi
--disable-vdadecoder --disable-external-ffmpeg --enable-optical-drive --enable-libcec --enable-player=omxplayer
