Full Version: Problems playing streams with 14.1 kodi on osx
Hi
I found a playlist with some indian tv streams and somehow when I play them in my raspberry pi they work fine, but on my mac mini (running 14.1 helix) they wont seem to run. In both I am using pvr tv simple client to load the playlist and play the streams.
I am not sure what the problem is here - I have copied over the log file below. Any help would be really appreciated.
10:31:04 T:140735163269904  NOTICE: special://profile/ is mapped to: special://masterprofile/
10:31:04 T:140735163269904  NOTICE: -----------------------------------------------------------------------
10:31:04 T:140735163269904  NOTICE: Starting Kodi (14.1 Git:2015-01-30-38e4046-dirty). Platform: OS X x86 64-bit
10:31:04 T:140735163269904  NOTICE: Using Release Kodi x64 build
10:31:04 T:140735163269904  NOTICE: Kodi compiled Jan 29 2015 by Clang 4.2 (clang-425.0.27) for OS X x86 64-bit version 10.6.0 (1060)
10:31:04 T:140735163269904  NOTICE: Running on Apple Inc. Macmini3,1 with OS X 10.9.5, kernel: Darwin x86 64-bit version 13.4.0
10:31:04 T:140735163269904  NOTICE: Host CPU: Intel(R) Core(TM)2 Duo CPU P7550 @ 2.26GHz, 2 cores available
10:31:04 T:140735163269904  NOTICE: special://xbmc/ is mapped to: /Applications/Kodi.app/Contents/Resources/Kodi
10:31:04 T:140735163269904  NOTICE: special://xbmcbin/ i s mapped to: /Applications/Kodi.app/Contents/Resources/Kodi
10:31:04 T:140735163269904  NOTICE: special://masterprofile/ is mapped to: /Users/nikhil/Library/Application Support/Kodi/userdata
10:31:04 T:140735163269904  NOTICE: special://home/ is mapped to: /Users/nikhil/Library/Application Support/Kodi
10:31:04 T:140735163269904  NOTICE: special://temp/ is mapped to: /Users/nikhil/.kodi/temp
10:31:04 T:140735163269904  NOTICE: special://frameworks/ is mapped to: /Applications/Kodi.app/Contents/Libraries
10:31:04 T:140735163269904  NOTICE: The executable running is: /Applications/Kodi.app/Contents/MacOS/Kodi
10:31:04 T:140735163269904  NOTICE: Local hostname: mac-mini.local
10:31:04 T:140735163269904  NOTICE: Log File is located: /Users/nikhil/Library/Logs/kodi.log
10:31:04 T:140735163269904  NOTICE: load settings...
10:31:04 T:140735163269904 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
10:31:04 T:140735163269904 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
10:31:04 T:140735163269904  NOTICE: Found 1 Lists of Devices
10:31:04 T:140735163269904  NOTICE: Enumerated DARWINOSX devices:
10:31:04 T:140735163269904  NOTICE:     Device 1
10:31:04 T:140735163269904  NOTICE:         m_deviceName      : default
10:31:04 T:140735163269904  NOTICE:         m_displayName     : Default
10:31:04 T:140735163269904  NOTICE:         m_displayNameExtra: Built-in Output
10:31:04 T:140735163269904  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
10:31:04 T:140735163269904  NOTICE:         m_channels        : FL,FR
10:31:04 T:140735163269904  NOTICE:         m_sampleRates     : 96000,48000,44100
10:31:04 T:140735163269904  NOTICE:         m_dataFormats     : AE_FMT_S24LE3,AE_FMT_S16LE
10:31:04 T:140735163269904  NOTICE:     Device 2
10:31:04 T:140735163269904  NOTICE:         m_deviceName      : AirPlay:stream0
10:31:04 T:140735163269904  NOTICE:         m_displayName     : AirPlay
10:31:04 T:140735163269904  NOTICE:         m_displayNameExtra: Kodi (OpenELEC)
10:31:04 T:140735163269904  NOTICE:         m_sampleRates     : 44100
10:31:04 T:140735163269904  NOTICE:         m_dataFormats     : AE_FMT_S16LE
10:31:04 T:140735163269904  NOTICE:     Device 3
10:31:04 T:140735163269904  NOTICE:         m_deviceName      : Built-in Output:stream0
10:31:04 T:140735163269904  NOTICE:         m_displayName     : Built-in Output
10:31:04 T:140735163269904  NOTICE:         m_displayNameExtra: Headphones
10:31:04 T:140735163269904  NOTICE:     Device 4
10:31:04 T:140735163269904  NOTICE:         m_deviceName      : Soundflower (2ch):stream0
10:31:04 T:140735163269904  NOTICE:         m_displayName     : Soundflower (2ch)
10:31:04 T:140735163269904  NOTICE:         m_dataFormats     : AE_FMT_S32BE
10:31:04 T:140735163269904  NOTICE:     Device 5
10:31:04 T:140735163269904  NOTICE:         m_deviceName      : Soundflower (16ch):stream0
10:31:04 T:140735163269904  NOTICE:         m_displayName     : Soundflower (16ch)
10:31:04 T:140735163269904  NOTICE:         m_channels        : UNKNOWN1,UNKNOWN2,UNKNOWN3,UNKNOWN4,UNKNOWN5,UNKNOWN6,UNKNOWN7,UNKNOWN8,UNKNOWN9,UNKNOWN10,UNKNOWN11,UNKNOWN12,UNKNOWN13,UNKNOWN14,UNKNOWN15,UNKNOWN16
10:31:04 T:140735163269904  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
10:31:04 T:140735163269904  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
10:31:04 T:140735163269904  NOTICE: Default DVD Player: dvdplayer
10:31:04 T:140735163269904  NOTICE: Default Video Player: dvdplayer
10:31:04 T:140735163269904  NOTICE: Default Audio Player: paplayer
10:31:04 T:140735163269904  NOTICE: Disabled debug logging due to GUI setting. Level 0.
10:31:04 T:140735163269904  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
10:31:04 T:140735163269904  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
10:31:04 T:140735163269904  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
10:31:04 T:140735163269904  NOTICE: Loaded playercorefactory configuration
10:31:04 T:140735163269904  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
10:31:04 T:140735163269904  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
10:31:04 T:4430041088  NOTICE: Thread ActiveAE start, auto delete: false
10:31:04 T:4466413568  NOTICE: Thread AESink start, auto delete: false
10:31:04 T:4466413568  NOTICE: virtual bool CAESinkDARWINOSX::Initialize(AEAudioFormat &, std::string &): Opening default device Built-in Output
10:31:04 T:140735163269904  NOTICE: Running database version Addons16
10:31:05 T:140735163269904  NOTICE: ADDONS: Using repository repository.xbmc.org
10:31:05 T:140735163269904  NOTICE: ADDONS: Using repository repository.xunitytalk
10:31:05 T:140735163269904  NOTICE: ADDONS: Using repository repository.xbmchub
10:31:05 T:140735163269904  NOTICE: ADDONS: Using repository repository.superrepo.org.helix.video
10:31:05 T:140735163269904  NOTICE: ADDONS: Using repository repository.pvr-osx64.xbmc.org
10:31:05 T:4467834880  NOTICE: Thread PeripBusCEC start, auto delete: false
10:31:05 T:140735163269904  NOTICE: Setup SDL
10:31:05 T:140735163269904  NOTICE: Display 0 has name H243H
10:31:05 T:140735163269904  NOTICE: Found possible resolution for display 0 with 1920 x 1080 @ 60.000000 Hz
10:31:05 T:140735163269904  NOTICE: Found possible resolution for display 0 with 1280 x 1024 @ 75.000000 Hz
10:31:05 T:140735163269904  NOTICE: Found possible resolution for display 0 with 1024 x 768 @ 75.000000 Hz
10:31:05 T:140735163269904  NOTICE: Found possible resolution for display 0 with 1024 x 768 @ 70.000000 Hz
10:31:05 T:140735163269904  NOTICE: Found possible resolution for display 0 with 1024 x 768 @ 60.000000 Hz
10:31:05 T:140735163269904  NOTICE: Found possible resolution for display 0 with 800 x 600 @ 75.000000 Hz
10:31:05 T:140735163269904  NOTICE: Found possible resolution for display 0 with 800 x 600 @ 72.000000 Hz
10:31:05 T:140735163269904  NOTICE: Found possible resolution for display 0 with 800 x 600 @ 60.000000 Hz
10:31:05 T:140735163269904  NOTICE: Found possible resolution for display 0 with 800 x 600 @ 56.000000 Hz
10:31:05 T:140735163269904  NOTICE: Found possible resolution for display 0 with 640 x 480 @ 75.000000 Hz
10:31:05 T:140735163269904  NOTICE: Found possible resolution for display 0 with 640 x 480 @ 73.000000 Hz
10:31:05 T:140735163269904  NOTICE: Found possible resolution for display 0 with 640 x 480 @ 60.000000 Hz
10:31:05 T:140735163269904  NOTICE: Found possible resolution for display 0 with 1280 x 1024 @ 60.000000 Hz
10:31:05 T:140735163269904  NOTICE: Found possible resolution for display 0 with 1600 x 1200 @ 60.000000 Hz
10:31:05 T:140735163269904  NOTICE: Found possible resolution for display 0 with 1024 x 576 @ 60.000000 Hz
10:31:05 T:140735163269904  NOTICE: Found possible resolution for display 0 with 1344 x 1008 @ 60.000000 Hz
10:31:05 T:140735163269904  NOTICE: Found possible resolution for display 0 with 1600 x 900 @ 60.000000 Hz
10:31:05 T:140735163269904  NOTICE: Checking resolution 15
10:31:05 T:140735163269904  NOTICE: GL_VENDOR = NVIDIA Corporation
10:31:05 T:140735163269904  NOTICE: GL_RENDERER = NVIDIA GeForce 9400 OpenGL Engine
10:31:05 T:140735163269904  NOTICE: GL_VERSION = 2.1 NVIDIA-8.24.16 310.90.9.05f01
10:31:05 T:140735163269904  NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
10:31:05 T:140735163269904  NOTICE: GL_EXTENSIONS = GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_depth_bounds_test GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_point_sprite GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
10:31:05 T:140735163269904  NOTICE: Running database version Addons16
10:31:05 T:140735163269904  NOTICE: Running database version ViewModes6
10:31:05 T:140735163269904  NOTICE: Running database version Textures13
10:31:05 T:140735163269904  NOTICE: Running database version MyMusic48
10:31:05 T:140735163269904  NOTICE: Running database version MyVideos90
10:31:05 T:140735163269904  NOTICE: Running database version TV26
10:31:05 T:140735163269904  NOTICE: Running database version Epg8
10:31:05 T:140735163269904  NOTICE: start dvd mediatype detection
10:31:05 T:4504662016  NOTICE: Thread DetectDVDMedia start, auto delete: false
10:31:07 T:140735163269904 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
10:31:07 T:140735163269904 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
10:31:07 T:140735163269904 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
10:31:07 T:140735163269904 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
10:31:07 T:4530376704  NOTICE: Thread LanguageInvoker start, auto delete: false
10:31:07 T:4531986432  NOTICE: Previous line repeats 2 times.
10:31:07 T:4531986432  NOTICE: Thread JobWorker start, auto delete: true
10:31:07 T:4531986432  NOTICE: PVRManager - starting up
10:31:07 T:4532523008  NOTICE: Thread PVRManager start, auto delete: false
10:31:07 T:4533059584  NOTICE: Thread PVRClient start, auto delete: false
10:31:07 T:4533596160  NOTICE: Thread LanguageInvoker start, auto delete: false
10:31:07 T:140735163269904  NOTICE: initialize done
10:31:07 T:4534132736  NOTICE: Thread LanguageInvoker start, auto delete: false
10:31:07 T:140735163269904  NOTICE: Running the application...
10:31:07 T:4533059584  NOTICE: AddOnLog: PVR IPTV Simple Client: Loaded 19 channels.
10:31:07 T:4530376704  NOTICE: -->Python Interpreter Initialized<--
10:31:07 T:140735163269904  NOTICE: Previous line repeats 2 times.
10:31:07 T:140735163269904  NOTICE: starting zeroconf publishing
10:31:07 T:140735163269904  NOTICE: Webserver: Starting...
10:31:07 T:140735163269904  NOTICE: WebServer: Started the webserver
10:31:07 T:140735163269904  NOTICE: starting upnp server
10:31:07 T:4611252224  NOTICE: Thread JobWorker start, auto delete: true
10:31:07 T:140735163269904  NOTICE: starting upnp renderer
10:31:07 T:140735163269904  NOTICE: ES: Starting event server
10:31:07 T:4622237696  NOTICE: Thread EventServer start, auto delete: false
10:31:07 T:4622237696  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
10:31:07 T:4622237696  NOTICE: UDP: Listening on port 9777
10:31:07 T:4622774272  NOTICE: Thread TCPServer start, auto delete: false
10:31:07 T:4533596160  NOTICE: -->Python Interpreter Initialized<--
10:31:07 T:4623847424  NOTICE: Thread AirPlayServer start, auto delete: false
10:31:07 T:4534132736  NOTICE: -->Python Interpreter Initialized<--
10:31:07 T:4625797120  NOTICE: Thread PVRGUIInfo start, auto delete: false
10:31:08 T:4629958656  NOTICE: Thread EPGUpdater start, auto delete: false
10:31:08 T:4532523008  NOTICE: Start - EPG thread started
10:31:08 T:4629958656  NOTICE: AddOnLog: PVR IPTV Simple Client: EPG file path is not configured. EPG not loaded.
10:31:09 T:4533596160  NOTICE: Previous line repeats 18 times.
10:31:09 T:4533596160  NOTICE:  StorageServer Module loaded RUN
10:31:09 T:4533596160  NOTICE: StorageClient-2.5.4 Starting server
10:31:17 T:140735163269904  NOTICE: DVDPlayer: Opening: pvr://channels/tv/All channels/14.pvr
10:31:17 T:140735163269904 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
10:31:17 T:4530888704  NOTICE: Thread DVDPlayer start, auto delete: false
10:31:17 T:4530888704  NOTICE: Creating InputStream
10:31:17 T:4530888704   ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 403
10:31:17 T:4530888704  NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
10:31:17 T:4530888704   ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
10:31:17 T:4530888704   ERROR: Open - failed to open source <http://yupptvrtmp-lh.akamaihd.net/i/blore7_ndtvenglish3@113071/master.m3u8>
10:31:17 T:4530888704  NOTICE: Creating Demuxer
10:31:18 T:4530888704   ERROR: OpenDemuxStream - Error creating demuxer
10:31:18 T:4530888704  NOTICE: CDVDPlayer::OnExit()
10:31:18 T:140735163269904  NOTICE: CDVDPlayer::CloseFile()
10:31:18 T:140735163269904  NOTICE: DVDPlayer: waiting for threads to exit
10:31:18 T:140735163269904  NOTICE: DVDPlayer: finished waiting
10:31:19 T:140735163269904  NOTICE: CDVDPlayer::CloseFile()
10:31:19 T:140735163269904  NOTICE: DVDPlayer: waiting for threads to exit
10:31:19 T:140735163269904  NOTICE: DVDPlayer: finished waiting
10:32:17 T:4466950144 WARNING: DARWINOSX: underflow (0 vs 4096 bytes)
10:36:08 T:4629958656  NOTICE: AddOnLog: PVR IPTV Simple Client: EPG file path is not configured. EPG not loaded.
http error 403 means Forbidden ... could you post a log of the same stream from the raspberrypi so we can compare it?
The log for the rasperry pi is located here: http://xbmclogs.com/show.php?id=420931
that is not a debug log (wiki)
Sorry - I followed the instructions and reloaded the logs for both. Played the same stream on both mac mini and osx at the same time and generated the debug log.
For Mac mini: http://xbmclogs.com/show.php?id=422183
For openelec/rpi: http://xbmclogs.com/show.php?id=422184
Please try the following:
In finder go into your Applications folder. Find Kodi.app - right clieck and click "show contents" - then naviaget to Contents/Libraries and move away the libcurl.dylib (might be called libcurl.dylib.4). Just move it to your desktop and ensure that it is not present in the Libraries dir anymore.
After that try it again and report back. (with debug log (wiki) again please).
Here is the link for the new debug log: http://xbmclogs.com/show.php?id=425093
A short "didn't work" in addition woul have been fine Wink
Well as of the looks it has something to do with the used curl version. OpenElec has a newer curl version. The problem is that on osx we can't use a newer libcurl. There is already a libcurl installed/coming with osx (thats what you forced it to use when you removed "our" libcurl from the libraries dir). We already tried to update the lib in our Libraries dir but the fact that there is one in the system which is loaded at the same time lead to symbol clashes and instant crashing. The version we deliver now is "compatible" with the currently delivered version from apple so it doesn't crash.
I have no idea yet on how to be able to really ensure that our lib is used (so we can bump version of it) as it always influences badly with the system version of the lib. No possible fix atm and as said i don't even have a plan on how this could be solved.
