General Support
OS independent / Other
> Removing thumbnails of deleted library sources.
Full Version:
You're currently viewing a stripped down version of our content.
View the full version
with proper formatting.
DankNasty
2015-02-08, 22:24
Is there a way to remove the thumbnails from library sources I deleted. I've removed some shows that take up around 400 megs and the thumbnails are still in the folder even after I cleaned library.
queeup
2015-02-09, 20:42
Texture Cache Maintenance utility:
http://forum.kodi.tv/showthread.php?tid=158373
If you know what you are doing very good python script for cleaning your library. Be very careful
just want to warn you.
General Support
