Full Version: Kodi unresponsive after switching to Reocorded TV
I'm running Kodi 14 on a client PC with a MediaPortal TV Server on a separate server PC. Everything was running ok for the last couple of weeks, but the last few days, Kodi Randomly freezes/becomes unresponsive when I try to open the LiveTV Recorded TV folder. I know that the Recorded TV folder should be visible, because it often happens when LiveTV is currently running (and therfore the link to the TV Server PC is active). However, it's also happened when nothing else is active.
Attached are the logs after the last crash, but the end of the logs might be missing b/c I was had to force close (as I always have to when this happens).
Cheers, Rich
Logs: http://pastebin.com/raw.php?i=CEq3Pnaj
