Hi Guys,
I'm trying to tweak an existing skin and whilst looking through the Kodi wiki pages on skinning I've noticed mention of "$LOCALIZE" in a number of wiki pages e.g. on the
label parsing page and the
label formatting page. However, it's not clear to me what exactly $LOCALIZE[something] does/returns and what is represented by what goes in the brackets.
Also, there's mention of strings.xml. Where is this mysterious file located? I can't seem to find it anywhere :|
Would really appreciate it if someone could kindly explain what they do and how to use them or point me to a source which can help.
![Wink Wink](https://forum.kodi.tv/images/smilies/wink.png)
strings.xml was the old xml-based format for translations, you now have to edit the strings.po file (located in language/xxx/ ).
$LOCALIZE[] basically explicitely tells kodi to translate that label id to the corresponding label. (have a look at the strings.po files and you will understand
![Smile Smile](https://forum.kodi.tv/images/smilies/smile.png)
be aware that there are also other labels available than the ones provided by the skin. Kodi for example has its own ones in Kodi-folder/language/)
(2015-02-09, 21:48)phil65 Wrote: [ -> ]strings.xml was the old xml-based format for translations, you now have to edit the strings.po file (located in language/xxx/ ).
Thanks Phil, it all makes sense now. The odd mentions of 'strings.xml' and $LOCALIZE without actually linking or mentioning languages in the wiki had me wondering what it was about.
![Tongue Tongue](https://forum.kodi.tv/images/smilies/razz.png)
Sorry to be really stupid, but I can't find where the Kodi system labels are stored. I've searched the Kodi directory in my programs directory and my roaming appdata folder for a strings.po file but the only ones I find are in the specific addons. The following is a segment of Ronie's code for Album Information in Transparency. I can't work out where the localize[563] comes from. The addon's own strings.po file starts at 31000.
<item>
<label>[UPPERCASE][B]$LOCALIZE[563]:[/B][/UPPERCASE]</label>
<label2>$INFO[ListItem.Property(Album_Rating)]</label2>
<onclick>noop</onclick>
</item>
Also, while here I really prefer star ratings to numbers, but if I change the label to $INFO[ListItem.Property(Album_StarRating)] it doesn't work. Is there a list item property for star rating?
Take a look at the KODI main string.po located in /Program files/KODI/addons/resource.language.en_gb/resources/
Brilliant - thanks guys - that saved me a few days of hunting.
So, 33067 is star rating. Just need to work out how to get the list item property.
BTW - the wiki still refers to strings.xml.
http://kodi.wiki/view/Label_Parsing
