2015-02-10, 00:06
My setup:
I have some Samba shares on my Linux machine where my videos are. I use these shares so I can connect my OpenElec (Raspberry Pi) to the Ubuntu server to play these files. Then I add these shared folders in Kodi using username & password to gain access.
So here's my problem. When I add a source I follow these steps:
22:57:39 T:140557703706368 NOTICE: Thread VideoInfoScanner start, auto delete: false
22:57:39 T:140558593845184 DEBUG: ------ Window Init (DialogExtendedProgressBar.xml) ------
22:57:39 T:140557703706368 NOTICE: VideoInfoScanner: Starting scan ..
22:57:39 T:140557703706368 DEBUG: CAnnouncementManager - Announcement: OnScanStarted from xbmc
22:57:39 T:140557703706368 DEBUG: GOT ANNOUNCEMENT, type: 16, from xbmc, message OnScanStarted
22:57:39 T:140557703706368 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
22:57:39 T:140557703706368 DEBUG: CAnnouncementManager - Announcement: OnScanFinished from xbmc
22:57:39 T:140557703706368 DEBUG: GOT ANNOUNCEMENT, type: 16, from xbmc, message OnScanFinished
22:57:39 T:140557703706368 DEBUG: Thread VideoInfoScanner 140557703706368 terminating
22:57:39 T:140558593845184 DEBUG: CGUIMediaWindow::GetDirectory (sources://video/)
22:57:39 T:140558593845184 DEBUG: ParentPath = [sources://video/]
22:57:39 T:140557703706368 NOTICE: Thread BackgroundLoader start, auto delete: false
22:57:39 T:140557703706368 DEBUG: Thread BackgroundLoader 140557703706368 terminating
Notice that the scan took ZERO seconds. Complete log is available. Have searched the forum for similar problems. I can browse the files when using the File option in Kodi. So I can individually assign a movie name, but that's tedious.
Also added files from the local disk instead of through SAMBA, but same result.
Anyone got an idea?
(EDIT: bump; another try and local files work......... baffled. I'm looking into the SAMBA problems and will post my findings for other users if I find an answer)
- Ubuntu 14
- Kodi Helix 14.1
- Samba for shares
- advanced settings for MySQL
- Goto videos-->Files
- Add source
- browse to folder
- enter username + password
- add the correct sub folder from the share
- repeat steps 3+5 to add all separate folders from each share
- indicate I use these shares for movies
- OK+OK+OK etc
Anyone got an idea?
